we are currently planning the floor layout. We have a design from the architect and our own draft, and we would appreciate your feedback. Thank you very much!
Plot size: approx. 2000 sqm (0.5 acres)
Floor area ratio (FAR): 0.18
Building envelope, building line, and boundary: rear alignment must follow neighboring buildings / building boundary
Number of floors: single-story, bungalow, no fixed staircase, access to attic via hatch with folding ladder
Roof type: gable or hip roof
Orientation: rear/terrace facing south, sunny from noon onward, some trees on the east side next to the house
Additional requirements: 2 m (6.5 ft) right of way along the western property line, adjacent to a relatively quiet side street
Homeowner Requirements
Building type: L-shaped bungalow
Basement, floors: no basement, 1 floor
Number of occupants, age: planned for 2 adults about 40 years old and 2 children, age- and wheelchair-accessible
Space requirements on ground floor and upper floor: 130–140 sqm (1400–1500 sq ft)
Office: family use or home office? Home office, attic accessed via folding ladder to be used as office
Occasional guests per year: separate small outbuilding on the plot for visitors
Open or closed architecture: closed, option to open access between kitchen and living room as needed (e.g., sliding door), kitchen and living room access to terrace
Open kitchen, kitchen island: kitchen island preferred (without stove), at least a counter with seating at worktop height, including a small “hidden” pantry
Number of dining spots: counter 3, dining table 8
Fireplace: undecided
Music/sound wall: no
Garage, carport: large garage for one Multivan + one car, 2 motorcycles, possibly bicycles, with the possibility to drive one car out of the garage into the yard from the rear
Utility room: large utility room (for technical equipment, washing machine/dryer, sink, plenty of space for drying racks/ironing, sports bags, etc.), with natural daylight
Additional wishes/particulars/daily routine, including reasons why some things should or should not be included:
- Second house entrance through the garage directly into the utility room and from there into the hallway leading to the cloakroom
- Living room approx. 30 sqm (320 sq ft)
- Bedroom (at the back) approx. 20 sqm (215 sq ft) + small walk-in closet, one wardrobe in bedroom, enough space around the bed
- Large bathroom with walk-in, barrier-free shower (approx. 2 m x 1.5 m (6.5 ft x 5 ft)), bathtub (not a corner bathtub), double sink, toilet
- Small guest bathroom including shower
- Preferably large window with seating area
- Windows/doors to garden/terrace possibly as sliding doors
Designer:
- House: architect
- Floor plan: 1x architect, 1x DIY
What do you like? Why?
Architect: combination of kitchen and living room
DIY: kitchen, access from hallway to dining area, hidden pantry, built-in cloakroom in hall, walk-in closet in bedroom
What do you not like? Why?
Architect: rooms lead directly from living room without hallway, utility room and bathrooms too small, utility room without natural light, office (= 2nd children’s room) accessed through kitchen, bedroom faces front, long distance between bedroom and main bathroom.
DIY: division of the angle between living room and bedroom probably not ideal?, long hallway is wasted space?
Preferred heating system: no idea yet
If you had to give up certain details/extensions
- Could give up: kitchen island, walk-in closet
- Cannot give up: access through utility room, kitchen separable from living room
How can kitchen, living room, and bedroom be optimally arranged in the rear corner of the house?
Designer:
- House: architect
Fromy21 schrieb:
The preliminary building inquiry was approved based on this. Our question here basically only concerns the floor plan. Okay, you had your chance. I can’t wish you anything more than good luck. If you come back, I won’t be counting on myself :-(
Fromy21 schrieb:
Our question here is basically just about the floor plan. Fromy21 schrieb:
A detailed plan/drawing will be the next step 😉. I just needed a rough idea for the layout first. Then I can look more closely at the square meters (square feet) / walls. Everything has been said: one and the other don’t work in different ways.
As long as you ignore the question about the budget, I will also stop paying attention here.
Everything has been said: neither of them works in different ways.
As long as you ignore the question about the budget, I will also stop paying attention here.Budget is not our problem. It is completely open. In case that helps.
Fromy21 schrieb:
Budget is not an issue for us. It’s completely open.
If that helps.No, that doesn’t help. We’re not planning any castles in the air here. Personally, I don’t want to waste time on that. Bye
