ᐅ Grooves/Cutouts in aerated concrete for KfW 40 standard
Created on: 30 Apr 2021 08:16
Markus254
Markus254
30 Apr 2021 08:16
In our shell construction (aerated concrete 42 cm (16.5 inches), KfW 40 standard), recesses for water connections, drains, downpipes, etc. are being built into the exterior walls. How deep/wide can such recesses usually be made before it becomes critical from a structural or energy-efficiency perspective?
Thanks and best regards
nordanney
30 Apr 2021 08:24
Table of allowable chase sizes in masonry according to wall thickness and chase depth.
Table of allowable vertical chases/recesses in masonry according to wall thickness and dimensions.
From an energy efficiency perspective, such chases are generally not significant.
Markus254
30 Apr 2021 08:33
@nordanney: Great, thanks a lot for the tables 🙂 ... Why are such slots not relevant for energy efficiency? Are the tapered sections in the mass negligible?
nordanney
30 Apr 2021 08:37
Markus254 schrieb:
Are the tapered areas in the mass negligible?
Exactly. That might affect about 0.5% of the exterior walls. And within that, there are also slots that only make up a small part of the wall thickness.
Myrna_Loy
30 Apr 2021 08:57
Just remember to insulate carefully when sealing the openings from the outside. Otherwise, the wall may discolor in those areas.
Markus254
30 Apr 2021 10:05
All right, thanks! What about concealed cisterns? 60 cm (24 inches) wide, 14 cm (5.5 inches) deep in a 42 cm (17 inches) wall.
