ᐅ Underfloor heating on the first floor is no longer working.
Created on: 29 Sep 2020 11:02
Q
qwertzuiop
Hello, we need some help.
The underfloor heating on the first floor is no longer heating, but it still works in the ground floor and basement.
The pressure gauge shows 1.2 bar. The heating system was serviced at the beginning of the year. I suspect that our 5-year-old godchild might have adjusted some valves.
I noticed that when I turn the red valves in the ground floor to a vertical position, the supply pipe on the first floor gets warm, but that’s all.
Could it be that something is incorrectly adjusted?
See pictures.
Mycraft29 Sep 2020 13:00
No, unfortunately it’s not that simple. "Open" already means 0.25 turns. You can’t determine that visually, and turning it without understanding won’t help.
Q
qwertzuiop
4 Oct 2020 15:03
Mycraft schrieb:
No, unfortunately it’s not that simple. “Open” also means just 0.25 turns. You can’t visually identify that, and turning it without understanding won’t get you anywhere.
Small update: I’ve now vented the floor six times, in the mornings and evenings over three days, and look, it’s running again.
But not at 100%, some rooms are cooler, some warmer, so it’s quite uneven. If you close the red valves on the ground floor, logically it speeds up the floor above.
Could it also be that the pump is no longer providing enough pressure?
Or that the valve inserts are sticking? See picture 1. I noticed some move freely when you press the pin in, but others are stuck tight. I’ve already sprayed some oil on them to help them move.
I also found that the screws shown in picture 2, which are on the supply line, are all loose. What is their purpose exactly?
Or could it also be because we have different blue caps since some were broken? Where can I get new ones? I already asked if they can be purchased separately, but apparently, they are only available with a new heating circuit manifold—that is, the blue caps.
Shut-off valve on a brass water pipe in a building services installation.
Several pipes (PVC) and a metal strap clamp on a wooden beam ceiling in the basement.
tomtom794 Oct 2020 16:15
Before you start making adjustments, you need to understand what they will affect. Usually, you only turn it once to set a flow rate that depends on the effective length, which then regulates the heat. Do you have any room thermostats?
T_im_Norden
4 Oct 2020 16:15
Do the metal parts at the bottom have a scale?
That is probably the flow rate.
Q
qwertzuiop
4 Oct 2020 16:41
tomtom79 schrieb:
Before you start adjusting things randomly, you need to understand what effect they have. Usually, you only turn it once to set a flow rate depending on the length of the system, which then controls the heat output. Don’t you have room thermostats?
No one is adjusting things randomly here, but yes, we do have room thermostats. However, we decided not to connect the electric actuators for financial reasons.
Q
qwertzuiop
4 Oct 2020 16:43
That should be the flow rate.
No, they don’t. You can see that in the first three pictures.
