ᐅ New single-family house, 190 sqm (aiming for fewer square meters!)
Created on: 15 Mar 2019 15:40
Lucrezia
Let’s give it a try 😉
We have finally decided on a local supplier who builds MHM walls (solid wood with wood wool insulation). It’s more expensive than a timber frame construction, but the local sourcing and construction method ultimately convinced us.
The floor plans were originally created by an architect, but we have gradually adapted them.
Of course, we will have “official” floor plans drawn up by the architect later. Before that, I’d like to exchange ideas with you and gather good suggestions 🙂
Hard facts:
We already live on the property in an older semi-detached house, which we will then rent out.
Plot size 470 sqm (total 1404 sqm, but part is already occupied by our old house, the double garage, and parking spaces).
The new house will have an “L-shape” to make optimal use of the free part of the property. The preliminary building enquiry with this plan was successful. The facade will be white! (or orange if approved).
The terrain is flat (needs about 60 cm (2 feet) of fill) – part of the topsoil will be reused, and whatever is missing will hopefully be “imported” from neighbors who are also building.
2 stories
Gable roof, between 25° and 28°
Style rather traditional
Orientation southwest
Client requirements
Style, roof shape, building type rather traditional, gable roof (requirements from local building authority/planning department)
No basement
Number of people, ages: she 45, he 50, 2 medium-sized dogs, children aged 1.5 and 2.5 years
Space needed on ground floor and upper floor – about 120 sqm (1300 sq ft) on the ground floor (due to practice), around 50 sqm (540 sq ft) upstairs would be enough
Practice with 2 rooms on the ground floor: 1 room purely as a practice, 1 larger room for courses/seminars as well. Soundproof wall between practice and living space. In 20 years or later, when we retire, the practice should become a granny flat (hence connections for kitchen + shower).
Guest sleepers per year – 5-6
Open or closed architecture – rather closed
Conservative or modern construction – doesn’t matter, main thing is practical
Open kitchen with island – more likely yes, but not mandatory
Number of dining seats – 3 to 6
Fireplace – only a stove
Music/stereo wall – unclear, possibly in the future?
Balcony, roof terrace – 1 balcony upstairs, 8.5 sqm (90 sq ft)
Garage, carport – no, already exists on the other part of the property
Utility garden, greenhouse – no, already present in the other garden area (maybe expand?)
Originally planned by the architect, now “copied” and modified by me
What do you like in particular? Why? Light! Relatively little “dead space” (entrance, hallway...). I want it bright, and all square meters used rationally and sensibly.
What don’t you like? Why? Practice WC without a window, but apparently it can’t be done differently. Probably still too little storage space because no basement (we have storage in and on the garage, but since we have several hobbies, I’m afraid it will be tight).
Especially upstairs I would like fewer square meters overall, and less corridor space...
Price estimate according to architect/planner: 430K
Personal price limit for the house, including fixtures: 510K
Preferred heating technology: heat pump without ventilation system (only in WC/bathroom), underfloor heating.
If you had to give up something, which details/extensions would it be?
- You could give up: parts of the entrance/hallway, living space upstairs
- You could not give up: practice, disabled-accessible practice WC. However, everything could be a bit smaller (overall house size, especially upstairs). A lower knee wall upstairs (currently 144 cm (4 ft 9 in)) is not feasible because on the south side, we would lose too much light.
Why is the design like this now? For example: Practice area
Do you see ways to avoid dead space? Reduce costs?
We have treated the upper floor somewhat as an afterthought, since we only need 1 bedroom, 1 guest room, 1 sauna, and not necessarily an extra office/dog room.
The layout is still open. There is definitely room for improvement and lots of opportunity for constructive ideas 🙂
*Note: no window on the south side is possible in the guest room, because the roof gable of the ground floor is there.
Hard facts:
2 stories
Client requirements
No basement
It would seem more typical for Bavaria to extend the roof over the practice extension, rather than adding a dormer there. Now I understand! We hadn’t considered a shed roof yet—it might be challenging with the height.
As Maria already mentioned, dormers are not uncommon here (my next-door neighbor, for example, has one).
hampshire17 Mar 2019 11:58Lucrezia schrieb:
Or just share the link or title of your floor plan thread?
We will actually have the new architect design our house.
However, the more ideas and clear concepts we bring in from the start, as you probably did, the more efficient the process can be. The description is post No. 5 in "Current Housebuilding Trends and Innovations..." from July 18.
It’s not about clear ideas of the house or rooms, but rather a description of how you want to live and what is important. For example, we wanted to create a blend of “indoors” and “outdoors” when it’s warmer. Minimal circulation areas and limited storage space (to reduce our belongings). Sunlight to wake up to, the boys should be able to become independent and stay as long as they want, while also building and learning a responsible life. We felt living in one open space has its charm, and we love cooking. Healthy living environments are important to us, and the house should generate more energy than it consumes. The forest on the property should serve as a CO2-neutral energy source. The house should fit harmoniously into its surroundings... and so on.
This is not a limitation for the architect, but a challenge, a creative brief. Actually, a dream project for an architect.
hampshire schrieb:
He received a bunch of pictures and examples that we gathered, each with a comment on what we liked about them. We knew that all these features couldn’t fit into one house. Exactly, that’s the "right" way to do it: the professional then tries to consider all the suggestions, while the self-planner tends to try to cram all suggestions in.
Lucrezia schrieb:
My immediate neighbor has something like this, for example Your closest neighbor is actually yourselves, along with the existing buildings that must be preserved next door. What do those actually look like?
Your closest neighbor is actually yourselves, with the existing buildings next door that you plan to keep. What do those look like?The large house next door where we currently live consists of two residential units, that is, a living area and a practice, and is rented out; we will continue to use the front garage, and probably will need to build a carport for the tenant.
I was referring more to the appearance, regarding the insertion.
Well, the other house dates back to 1952, but due to the rather conservative construction style, the new one will fit well in the picture.
If we were allowed, we would build something a bit different (e.g., a flat roof with a parapet, green roofing, usable as a terrace). Unfortunately, this is not possible in this part of Bavaria.
