Reini123422 Feb 2019 08:22We are currently considering the best way to control our blinds and shutters. Attached are a floor plan and the following explanations:
- There is a basement, but it is operated manually with a strap.
- The ground floor has electric blinds in the large living area (5x), while the rest of the ground floor and the upper floor have electric shutters.
- The house is located on a south-facing slope, meaning if the sun is out, we get sunlight all day until it sets.
- The neighbor is opposite the front door and on the left side of the plan. To the right and below the balcony there are no neighbors, as these areas cannot be built on.
- The windows in the guest and guest bathroom on the ground floor face a street, which is a dead end. Only the neighbor opposite and occasional pedestrians pass by here.
- Of the children’s rooms, one is still free, and the other is occupied by a 3-year-old child.
We have decided on a PLC (programmable logic controller) system with functions for dusk, time, wind, and sun, combined with an indoor temperature sensor. Each motor can also be operated manually via a button. However, we are unsure how many motors to integrate into the control system. Initially, we only planned a control system for the blinds.
Our thoughts:
- Does it make sense to include the entire ground floor? For the windows outside the living area, only the dusk function would be relevant. On the other hand, do we even need that where there is hardly any public traffic?
- Does it make sense to include the entire house, using a similar reasoning as above?
- Does it make sense to only include the children’s rooms due to expected sun exposure? However, these are equipped with shutters that almost completely darken the rooms, and there will likely be different “bedtimes” as well.
Here is the cost aspect:
6x motors 400 EUR
8x motors 475 EUR
10x motors 600 EUR
12x motors 790 EUR
I know there is no one-size-fits-all solution, but I would still be interested in your opinions.
Our thoughts:
6x motors 400 EUR
8x motors 475 EUR
10x motors 600 EUR
12x motors 790 EUR
Steffen8022 Feb 2019 08:30Why choose PLC instead of KNX? Wouldn't that even be more cost-effective?
Reini123422 Feb 2019 10:21A KNX control system with 12 roller shutters for 790 EUR plus 100 EUR for a weather station? That seems a bit cheap to me (although I haven’t researched it).
Well, in terms of components, it is comparable.
500 for the actuator channels
200 for the weather station
70 for the bus power supply
130 Euro for the KNX/IP interface
However, the switches/push buttons are still missing, meaning that with KNX the whole system would only be controllable via phone/tablet, but most likely with a greater range of functions and flexibility than with a PLC.
Reini123422 Feb 2019 13:06And the labor cost for programming is also missing. KNX is out for me; it will definitely be a PLC control.
All motors can still be operated via the local push buttons.
