ᐅ Prefabricated House vs. Solid Construction: Which Is Better and Why?
Created on: 24 Oct 2018 21:00
O
Oecsi2018
O
Oecsi2018
24 Oct 2018 21:00
Hello everyone!
I’m new here and hope my question is in the right section.
We have reserved a plot of land (550 square meters (5900 square feet) with a slight slope). Now we are in the process of requesting and comparing different offers. So far, the options are:
1. Solid construction house providers
2. Ytong (aerated concrete) kit suppliers
3. Prefabricated house providers
First, a general question:
Solid construction house versus prefabricated house –
Is one better than the other? How do they compare, for example, in case of water damage? Why choose one over the other? Or are there no real quality differences? Please help us!
Thank you!
11ant25 Oct 2018 00:43
Oecsi2018 schrieb:
Or are there really no qualitative differences?
Not really, when comparing similar features at similar prices.
When the general public or laypeople say "prefabricated house," they are simplifying and usually mean a house made from timber frame panels. The reality is different: first, the house is not "finished," but "prefabricated," and this only applies to the shell structure. The actual construction time is not shorter, only the assembly time of the shell elements is reduced. Second, there are now also some providers of prefabricated walls made from solid building materials (mostly aerated bricks).
The "kit house" option is built "brick by brick," and there are also prefabricated houses available as “shell construction” or “unfinished houses.” In both approaches, you can find options for partial or full self-builders.
I no longer belong to a minority group holding the opinion that prefabricated houses are comparable in quality, but you will still easily find people who see them as inferior "shacks."
And if you think choosing a solid construction house (masonry) settles the debate, then you are only moving on to the next round: the next question will be "calcium silicate brick or aerated concrete or porous brick or expanded clay or pumice or shuttering blocks," or "monolithic or insulated composite system." Each "group" has passionate advocates and critics.
The main practical difference is probably that prefabricated house providers (whether timber frame or masonry) operate nationwide, while solid construction builders—and increasingly timber frame specialists—tend to be local, often owner-operated businesses.
My advice is: if you are not yet firmly committed to one building method or another, don’t get too stressed. Instead, find a house supplier or contractor with whom you have good chemistry. Let them use the construction method they have the most experience with; this is the safest way to achieve a good result.
25 Oct 2018 00:46
Look at the top right... the search function... this question comes up repeatedly... there are many threads over the years. Some interesting discussions can be found.
Mottenhausen
25 Oct 2018 12:13
11ant summed it up perfectly. This is a matter of personal belief and intuition.
After last summer (2018), we decided on a solid construction house (sand-lime brick + external thermal insulation composite system). The indoor climate feels more comfortable. It’s a matter of personal preference.
Some prefabricated house providers are even more expensive because the houses today are built with high-quality materials and come standard with various technical features. The so-called "infamous" Allkauf self-build house is, of course, the most affordable way to get your own home.
Therefore: first set a budget (consultation appointment at the bank), then get initial offers and try to get a sense of "how much house I can afford."
face2625 Oct 2018 12:53
…and you can further divide the term "solid house" into categories like general contractor (GC) or architect, and so on.
On one hand, it’s a matter of personal belief; on the other hand, it depends on what you want or don’t want.
I recommend gathering a lot of information, talking to many people, visiting a model home park, and having a conversation with a GC… while being aware that everyone prefers their own "system."
Usually, over time, a clearer picture emerges. At least, you develop more concrete wishes or ideas… some don’t care at all if it’s a "cookie-cutter house," while others absolutely reject that. Some feel comfortable with systems offered by prefab house providers or GCs because they provide more "guidance," whereas others prefer the freedom to decide everything individually, as with an architect, for example.
haydee
25 Oct 2018 12:58
More important than the wall construction is having a contract partner who suits you and understands what you want.
