ᐅ Is the staircase layout in the floor plan acceptable? What does the number 18.3/28 mean?
Created on: 8 Jun 2018 13:58
Pädda
Pädda
8 Jun 2018 13:58
Hello. I received a floor plan where the staircase is marked with 16 risers 18.3/28. Can you tell me what the number 18.3/28 means? I have no idea what it refers to.
hanse987
8 Jun 2018 14:19
18.3 cm (7.2 inches) riser height, 28 cm (11 inches) tread depth
kaho6748 Jun 2018 14:32
Show us the floor plan. 🙂
8 Jun 2018 23:50
hanse987 schrieb:
183mm (7.2 inches) step height, 280mm (11 inches) step depth
What was the standard again? 160mm/290mm (6.3 inches/11.4 inches) or 190mm/260mm (7.5 inches/10.2 inches)?
11ant9 Jun 2018 00:26
The latter. But more as a common measurement that is often approached. I would still consider "standard" to be too strong a term for it.
9 Jun 2018 00:34
The latter. But rather just a dimension that is often approached. I would still find “standard” too strong a word here.
Then the dimensions in the post should be convenient 🙂
