ᐅ Sealing on bamboo flooring is scratched
Created on: 22 Aug 2017 18:28
HilfeHilfe
HilfeHilfe
22 Aug 2017 18:28
I have a possibly silly question.
Due to furniture being moved and children playing, I noticed that the sealant on the parquet floor has "cracked."
Is this a problem, or would you recommend sealing it? Is there a repair kit available for this?
Or should I just leave it as is, although it does look a bit unattractive.
Close-up of a wooden floor surface showing grain, planks, and scratches.
Nordlys
22 Aug 2017 19:24
That needs to be closed. It’s not entirely straightforward, though. The torn area will have to be sanded extensively to smooth the edges. Then, spray paint is applied. After that, the overspray is removed by wet sanding with 1000 grit. This is a job for a professional painter. It’s doable and probably only about 30 minutes of work. But you have to know how. Do you know an automotive painter? Karsten
HilfeHilfe
23 Aug 2017 06:50
Nordlys schrieb:
That needs to be sealed. It’s not exactly easy though. You have to sand the cracked area more extensively to even out the edges. Then apply spray paint. After that, wet sand the mist with 1000 grit sandpaper. It’s a job for a professional painter. It can be done. It probably takes only about 30 minutes. But you need to know how. Do you know an auto painter? Karsten
No... does it have to be done by an auto painter?
Which spray paint do you recommend?
Nordlys
23 Aug 2017 07:59
This does not have to be done by an automotive painter. However, someone like that will certainly know how. A skilled professional painter will probably know as well. Spray paint brand: No idea what is compatible. Most likely something acrylic-based. Karsten
RobsonMKK23 Aug 2017 08:08
No offense, but it might be better to have a flooring specialist handle that instead of a car painter/decorator. After all, repairing floors is part of their everyday work.
HilfeHilfe
23 Aug 2017 09:15
RobsonMKK schrieb:
No offense, but maybe you should call a parquet floor installer instead of a car painter/decorator. After all, repairing floors is part of their daily work.
In Hesse, no parquet installer will come for just 2 scratches....
