ᐅ Sound Insulation / Thin Walls in Prefabricated Houses, Solution by Okal Company
Created on: 19 Mar 2016 10:54
C.Krommen
C.Krommen
19 Mar 2016 10:54
we are currently interested in purchasing a prefabricated house from Okal Haus.
This will be built as a "house within a house" solution, which means a wide single-family house is constructed and then divided in half with a double exterior wall, including an air cushion between the walls.
Does anyone have experience with the sound insulation, both in relation to the neighboring house and how much noise carries within the house itself? (For example, if a child takes a step in one corner of the house, can you immediately hear it in the other corner?)
Thank you in advance for your responses!
Bauexperte
19 Mar 2016 23:01
Good evening,
just for better understanding:
C.Krommen schrieb:
This is being built as a "house within a house" solution, meaning essentially a wide single-family house is constructed and then divided in half with a double exterior wall including an air gap between the walls.
You don’t mean the traditional semi-detached house, but a house with one entrance that leads to two separate apartments? So divided according to the condominium ownership system?
Best regards, Bauexperte
