ᐅ Replacing the Heating System in an Older Home – Gas or Air Source Heat Pump
Created on: 27 Sep 2020 07:37
Jule_NeuDear forum members,
We recently purchased a house and have been in contact with our heating contractor for some time, considering how to upgrade the heating system. The house is an end-of-terrace with a split-level design – meaning the floors are mostly open to each other. Currently, there is a relatively new gas condensing boiler installed, about 4 years old. The problem is that all radiators are connected to a one-pipe system, which is very inefficient and also incompatible with future heating systems. This was the main reason we started thinking seriously about the heating system. Otherwise, we would have just replaced a few radiators.
After many discussions and considerations, we have at least decided that we want to switch to underfloor heating. The rooms are quite small, the radiators significantly interfere with the interior design, and we have a small child who usually spends half the day on the floor. Since the whole house needs renovation anyway (floors, walls, bathrooms), we will be removing everything regardless. Installing the underfloor heating would not cause much additional effort.
Our heating contractor suggested underfloor heating combined with an air-source heat pump, partly because there are currently good subsidy options for this. At first, we really liked the idea, but doubts are beginning to arise. Our house is exactly 3 meters (10 feet) from the neighbor’s boundary, and the air-source heat pump would have to be installed within this 3-meter (10 feet) space. We definitely want to avoid any trouble with the neighbors, and we are also unsure if we would get annoyed by the humming noise from the air-source heat pump eventually, since our kitchen window/dining area would be directly above the unit.
So we are now wondering if it is really necessary to replace the existing condensing boiler. Could we not run the underfloor heating using this existing system? Of course, we would lose the subsidy, but this seems more reasonable to us right now. Or are we mistaken and do gas costs then skyrocket when operating an underfloor heating system?
Another point that bothers us is the relatively high electricity costs of the air-source heat pump. By our calculations, the electricity costs would be roughly the same as the gas consumption with the current gas heating system (the house is still rented, so we know the consumption). Aside from the ecological aspect, we can’t see any advantage for us.
We would really appreciate your feedback, as we need to make a decision soon.
Definitely keep the gas heating system if the subsidy does not cover 100% of the costs for the air-to-water heat pump. Also, it’s not about a possible requirement but rather the supply temperature. An air-to-water heat pump can only operate efficiently with a very low supply temperature.
What insulation measures are you planning?
T_im_Norden27 Sep 2020 08:30You need to calculate this precisely and determine the heating demand based on the insulation.
There are both KfW programs for renovation as well as Bafa subsidies.
Since all measures for underfloor heating can also be subsidized in older buildings, it can definitely be worthwhile to replace the BWT.
T_im_Norden schrieb:
You need to calculate this precisely and determine the heating demand after insulation.
Since all measures related to underfloor heating can also be subsidized in older buildings, it may well be worthwhile to replace the BWT. We have roughly estimated this based on an offer from our heating installer. Since there is apparently also funding available for reinstalling the floors, both options would be about the same cost for us. For us, as mentioned, the noise factor is still a concern. Or have the new units become significantly quieter by now?
Jule_Neu schrieb:
Noise Factor??? What noise? From the heat pump? That’s just a rumor. There are isolated cases – just like there are isolated cases where indoor units make noise (even a gas heating system produces sounds).
