ᐅ Countertop Lighting – URail System by Paulmann
Created on: 14 Jan 2018 20:28
bibi80
We are currently considering the lighting for the worktop. Since we have only one upper cabinet, we plan to use the URail track system from Paulmann.
Maybe some of you have experience with this system.
If so, I would appreciate it if you could answer the following questions:
- Which spotlights do you use?
- Does the lighting sufficiently illuminate the worktop?
We planned to position the track 30cm (12 inches) from the front edge of the worktop. Is that correct?
If possible, could you also share some pictures so I can see how you have set it up?
Thank you.
Birgit
Deliverer
26 Aug 2020 08:44
In fact, the rails are the only components of the system that are manufactured with relatively high quality. (This becomes especially noticeable when cutting them.) The materials are appropriate. Unfortunately, this is quite the opposite for all the possible attachments. Nevertheless, I continue to use it and also equip new rooms with it, as there is unfortunately no comparable system available on the market.
Shiny86
26 Aug 2020 11:26
Are there no high-quality add-on components?
Deliverer
26 Aug 2020 12:42
There probably are, but for many parts (power inputs, connectors, switching actuators) you don’t get a choice and have to use the very overpriced pieces made from cheap plastic. It doesn’t help much if some of the light fixtures are higher quality (though probably still not cost-effective).
That said, I have chosen this system several times because it’s very flexible, makes later modifications or additions easy, and is visually unobtrusive.
pagoni2020
26 Aug 2020 12:50
I also think that this Paulmann system is pretty decent; we have installed some of it here. Of course, you can also use products from Oligo, Erco, and others, but as always, it comes down to the price. You need to decide that beforehand. More, better, and more expensive is always an option.
Shiny86
26 Aug 2020 14:58
What did you pay for your U rail solutions?
Deliverer
26 Aug 2020 15:05
Of course, this varies depending on the requirements, and I have made some changes along the way. But roughly: $600 for the kitchen (10 light fixtures) and $400 for the bathroom (8 light fixtures). Plus bulbs, since I only have a few integrated lights.
