ᐅ Wood beams infested with woodworm – Is there anything that can be done?
Created on: 24 Oct 2018 19:02
Kimi190
Kimi190
24 Oct 2018 19:02
I own a half-timbered house built around 1800. The timber framing was already completely covered and, except for the rear facade, fully insulated when I received the house as a gift. Now I want to also cover the rear wall with a ventilated insulation system. Currently, the facade is covered with tar paper boards designed to look like brick. When I looked at the beams behind the timber frame facade, I noticed that one beam appears to have been infested by woodworm. On an area of 2x2cm (about 1x1 inch), the screwdriver went through very easily. Around this spot, the beam is completely solid and can only be adjusted with force using a screwdriver. Is this critical, and does the beam need to be replaced or should it be? That would, of course, be a huge effort.
25 Oct 2018 13:07
Have a professional on site take a look.
There is nothing more to say about it.
The condition of a beam cannot be assessed or evaluated through guesswork.
Even if you had posted a required photo here, a remote diagnosis would be pointless.
Today, there are methods to replace even just parts of a beam, but any signs of dry rot, insects, or fungus should be examined by a specialist.
fach1werk
26 Oct 2018 18:40
Beams can become soft for various reasons; animals are only one part of the causes, and woodworms are not the only ones that nibble on the wood. I won't go into all the details.
Woodworms generally target softwood that is less than 50 years old. After that age, the protein has broken down, so even the most modest worm would find it hard to feed. You can identify an active worm by the presence of wood dust, and in severe cases, you might even hear a faint "sawing" sound during quiet moments. But let's not assume that here 🙂
You need a professional! I would kindly suggest contacting your local heritage protection authority and, if possible, asking for an inspection. Structural integrity is not something to take lightly—you will need a reliable assessment. Timber-framed houses are like surprise eggs: you can shake them but you won’t really know what’s inside until you open them up. Repairs and extensions are possible.
Beams can be saved, and in historic buildings, you often see patched sections in long exposed roof structures. If it’s only a small section (2m (6.5 feet) is considered small; the process itself is expensive), you can stabilize it with an injection method without removing it. Essentially, this means filling the beam with resin through suspended injection syringes, although it may already be a little too cold for this. The beam will still look like a beam, but the resin is actually carrying the load.
Wishing you the best of luck!
Gabriele
