ᐅ Even with careful assembly, the Kallax still wobbles slightly – why?
Created on: 18 Oct 2024 09:13
keemilia39
I recently assembled a Kallax shelf from IKEA and despite careful assembly, it wobbles slightly when gently tapped or lightly loaded. I have checked all screws multiple times, the individual parts are positioned exactly as they should be, and I have followed the assembly instructions meticulously. However, there is still some noticeable instability, especially when the shelf is empty or only lightly filled.
I would like to understand: Why does the Kallax shelf wobble slightly despite careful assembly? Is it due to the design, the material, or typical Kallax construction methods? Are there any tips or specific measures to significantly improve its stability? I appreciate any objective advice.
lisku
19 Oct 2024 09:14
There are special furniture pads with rubber surfaces that compensate for unevenness and prevent slipping. They can be quickly attached underneath and often work wonders for wobbling.
Alternatively, small carbon covers on the corners or sturdy felt gliders can be used. Costs are minimal and effort is almost none.
ju_ren
19 Oct 2024 09:45
lisku schrieb:
special furniture pads with rubber backing
Exactly, they provide better grip on smooth floors and prevent wobbling. Easy to get and effective.
blapau
19 Oct 2024 12:37
I would like to point out that the Kallax design does not include additional reinforcement through diagonal bracing; these are simply absent by design. However, anyone who installs a small diagonal brace made of metal strips inside will gain significantly more stability in the side panel.
This is especially useful if the shelving unit is subjected to heavy loads or placed on a very uneven surface.
Filippo
19 Oct 2024 14:23
blapau schrieb:
install a small diagonal brace made of metal strips on the inside
That is a good addition. Metal brackets or flat steel strips are then screwed to the back and side panels, which significantly increases the torsional rigidity.
Care should be taken to ensure the screws go into the thicker edges of the Kallax frame and not just into the thin back panel, to properly stabilize the shelf.
keemilia39
20 Oct 2024 10:12
Thank you all for the detailed and helpful responses. I now have a clear understanding of why a Kallax shelf often wobbles slightly despite careful assembly: the material thickness, the design without fixed cross braces, manufacturing tolerances, and the lack of wall mounting are the main reasons.
I will first try using furniture glides and then reinforce the back panel or install a wall bracket. If I have any further questions, I will be happy to reach out again.
Thanks again for the patient explanations and all the practical tips!
