ᐅ The windows are smaller than specified in the building permit/planning permission or construction plans.
Created on: 22 Dec 2019 18:57
Sunshine12345
we have a problem with the windows in our new build. Unfortunately, the discrepancy was only discovered after the house handover. According to the building permit/plans, the windows should be 6cm (2.5 inches) taller than they currently are. The sill height is also 6cm (2.5 inches) too high. This is very frustrating for us, as this height was a compromise and I would have preferred even larger windows...
Does anyone have advice on how to proceed?
Thank you very much
22 Dec 2019 21:08
What exactly is “too small” there? After plastering? The raw construction? Dimensions in drawings usually refer to the raw construction as well, how is it with you? And 6 cm (2.4 inches) on what? On windows that are one meter (3.3 feet) or two meters (6.6 feet) wide?
Pinky030122 Dec 2019 23:18
Have you asked how the difference comes about?
Sunshine12345
22 Dec 2019 23:52
Yes, we inquired as soon as we noticed it. However, the answer does not make sense.
Yesterday, I reviewed an old chat history. Now the discrepancy becomes clear. It seems that the window height was taken not from the building permit / planning permission, but from older plans.
Mycraft23 Dec 2019 00:19
The classic case... sorry, there’s nothing more that can be done.
Pinkiponk
23 Dec 2019 10:13
Once again, I am shocked by this issue. As a non-professional homeowner, do I really have to crawl into every corner of the construction site every day and measure everything down to the centimeter (half an inch)? I just don’t understand this entire industry. I consider it standard practice to do one’s job well, precisely, and without errors (with only a few exceptions), but in the construction sector, it seems to be the opposite. Our prefabricated house build will be supervised by an independent expert, but by now, I feel that one is not enough. Maybe adding inspections by TÜV or DEKRA as well. Having to measure every single window as the homeowner seems quite absurd to me.
Pinkiponk
23 Dec 2019 10:15
Mycraft schrieb:
The classic... sorry, nothing can be done about it anymore.
In what way is it the classic? I’m asking because I would like to avoid the situation mentioned above.
