I want to order granite sills. I have a brick facade with beige ceramic bricks.
Question about the drip groove on both sides, there will be a drip edge:
Is it practical or not?
The disadvantage I have understood so far:
aesthetic
The stonemason will do it for me free of charge.
Thanks
aesthetic
Thanks
hampshire schrieb:
Those are true wonder grooves that hold back water moved by the wind!Well, something like that! Let the original poster take a look at samples. The groove wouldn’t exist if it didn’t serve a legitimate purpose. And we’re definitely not talking about aluminum window sills!tumaa schrieb:
Then I’ll just make compromises on the appearance. I don’t see it as a compromise; the grooves don’t have bright red edges anyway.
hampshire schrieb:
Those are real miracle grooves that stop water moved by the wind! Nonsense, no miracles. The windowsill is sloped lengthwise, but level across >>> Result: precipitation drains evenly across the width. However, the ideal conditions of still wind and perfectly vertical rainfall rarely occur. The deflected wind-driven rain is pushed sideways on the windowsill depending on wind direction—so on one side toward the reveal—and would cause higher wetting there. Along this path, a groove allows some of the water to drain away. And it’s actually quite a significant amount, since the groove is several water-layer heights deep. No magic—just a simple drip edge or whatever it’s called.
Vicky Pedia schrieb:
And we’re definitely not talking about aluminum windowsills! With those, an upstand additionally provides stability for the overhang.
