ᐅ Window sill height 130 cm in the bedroom / home office?
Created on: 23 Nov 2021 17:37
audiophiloneA
audiophilone23 Nov 2021 17:37Hello... we have the following issue. Since we don’t want too many different window heights in the house and also don’t find the transition from a 130cm (51 inches) sill height to a low window in the same room or at the junctions particularly attractive, we are facing the above-mentioned problem. Actually, I’m not even sure if it’s really a problem.
hampshire23 Nov 2021 17:44I would always build from the inside out. If the windows fit well into the rooms, that is the right approach. If the rooms would benefit from a different shape or a different sill height, I would prefer to choose more varied windows on the facade or find another solution that meets all the requirements.
hampshire23 Nov 2021 17:54Can you incorporate light from above because of the flat roof? This will make the rooms brighter while keeping the external window lines clear and proportionate as desired.
audiophilone23 Nov 2021 17:55Meeting all the requirements is not easy, and that is exactly where our problem lies. @ypg But don’t you think a 265cm (8 ft 8 in) and a 201cm (6 ft 7 in) window would not let in enough light?
audiophilone23 Nov 2021 17:56@hampshire I hadn’t thought of the idea from above yet... but I’m not really sure how exactly that would work.
