ᐅ Window frames: white or anthracite?
Created on: 23 Jul 2023 09:51
Moni1969
Moni1969
23 Jul 2023 09:51
Hello, we are deciding between white or anthracite for the window color. The exterior is anthracite, but what about the interior? Who else was unsure and how did you decide? Would you choose the same again now? Good luck. Moni1969
KarstenausNRW
23 Jul 2023 10:48
The choice of probably 99% of people is clear. A strong anthracite color stands out immediately on any wall. You either like it—or, like most home builders, you don’t.
Aside from that, anthracite looks quite dull on the exterior ;-)
Pitiglianio
23 Jul 2023 11:21
We chose anthracite on the outside and white on the inside.
Inside, the contrast with white walls and ceilings would have been too strong for us. Only the darker floor is meant to provide the desired contrast here.
KarstenausNRW schrieb:
Besides, anthracite on the outside is boring
It’s no more boring than white or colored. It’s the right facade or facade color that really makes the difference.
But of course, it’s a matter of personal taste, says the monkey and bites... just kidding...
Moni1969
23 Jul 2023 11:58
Pitiglianio schrieb:
We chose anthracite for the exterior and white for the interior.
Inside, we thought the contrast with white walls and ceilings would be too strong. Only the darker floor is meant to provide the desired contrast here.
It’s no less boring than white or colored. The right facade or facade color really makes the difference.
But of course, it’s a matter of personal taste, says the monkey and bites… just kidding…
We have a fairly light floor, the walls are very light gray, and the kitchen is anthracite.
Pitiglianio
23 Jul 2023 12:03
Moni1969 schrieb:
We have a fairly light floor, the walls are a very light gray, and the kitchen is anthracite.
In this particular case, the gray window frames on the inside could work quite well. But of course, you'll have to decide for yourselves.
hanse987
23 Jul 2023 12:12
In this particular case, the gray window frames could of course look good on the inside. But
However, you should carefully check the exact colors of both to make sure they don’t clash. Even different levels of gloss can make a big difference. I would always compare sample pieces. While not always 100% conclusive, it’s a good reference point.
