ᐅ Window damaged – How can this happen?
Created on: 24 May 2022 18:09
Nutshell
How is this possible? North-facing and no physical impact, the window is 8 years old.
We have no idea, of course. There is a heat lamp for the changing table nearby—could it be caused by that? It should actually be 20cm (8 inches) lower, not at this height, but okay...
Is this just a cosmetic defect? (It is in the nursery.)
Side view of a window frame with black profiles, white seals, and insect screen.
Window frame with insect screen, handle at the bottom; view outside to green meadow, road, and distant houses.
HilfeHilfe
25 May 2022 10:04
Better the window than the baby!!
Tolentino25 May 2022 10:07
But that is just the mounting rail, which can be easily replaced if necessary. You can actually do it yourself as well...
Neubau2022
25 May 2022 10:08
Heat radiators for babies. Reminds us of our daughter. She was wrapped in cotton wool balls. If there were a second child, we would probably change them on the snow in winter :-) With the first child, you are shy like a deer 😎
SoL
25 May 2022 10:19
Neubau2022 schrieb:
Heat lamp for the baby. Reminds us of our daughter. She was wrapped in cotton balls. If we had a second child, we would probably change them outside on the snow in winter 🙂 With the first child, you’re as cautious as a deer 😎
Yes, child 1 had something like that here too.
Children 3 and 4 are expected to change themselves in the rain :p
guckuck2
25 May 2022 11:08
Neubau2022 schrieb:
Heat lamps for babies. It reminds us of our daughter. She was wrapped up in cotton balls. If we had a second child, we would probably change them outside on the snow in winter 🙂 With the first child, you are as cautious as a deer 😎
Off-topic incoming... we also bought one of those as part of the "initial equipment." In the end, hardly any changes were done on the dresser, and by the time the heat lamps warmed up, the diaper change was already over. A baby won’t suffer from 5 minutes at room temperature, not even naked.
