ᐅ Why is the front edge of my Billy table extension squeaking?
Created on: 10 Apr 2023 08:23
Pramishel
Pramishel
10 Apr 2023 08:23
I have a Billy tabletop extension from Ikea, and I noticed that the front edge squeaks slightly when under load or movement. The noise usually occurs when I gently pull the tabletop forward or slide something on it.
I suspect the squeaking might be caused by wood-on-wood friction or possibly the fasteners, but I’m not sure. It’s probably not the hinges on the sides, since the squeaking clearly comes from the front edge.
Does anyone have an idea what might be causing this? Could it be due to missing lubrication or maybe a slight deformation of the wood?
I would really appreciate any tips on how to specifically fix the problem or at least narrow down the cause. Thanks!
juMira46
10 Apr 2023 09:07
That sounds really annoying, but at least you’ve identified the culprit—the front edge. 😅 Often, squeaking in furniture, especially with Billy, is simply a combination of moisture, slight friction between wood or chipboard, and lack of lubrication.
My advice: try rubbing a bit of furniture wax or candle wax onto the front edge. This often works wonders because it makes the wood slightly smoother and reduces friction without damaging anything. Just make sure to clean the surface beforehand!
What do you think? Have you tried that already, or are you worried that waxing might discolor the surface?
klo40
10 Apr 2023 10:18
I agree with the tip about using wax but would like to explain possible causes in more detail:
1. Material & Construction: Billy table tops are usually made of particleboard with a melamine-coated surface. This can easily rub at the edges during movement, especially if the panel is not perfectly fitted or slightly warped.
2. Check Fastenings: Screws and connectors along the front edge and sides can loosen over time, causing unwanted movement and therefore squeaking.
3. Moisture: A damp environment causes wood/particleboard to swell, which increases friction.
My advice:
- Tighten the screws.
- Carefully smooth the front edge with fine sandpaper to even out small irregularities.
- Then, as suggested by juMira46, treat the surface with furniture wax.
Summary: Check the fastenings and the fit before addressing lubrication.
SUBEN60
10 Apr 2023 12:43
In addition to the previous suggestions, I would like to point out that the squeaking can also be caused by mechanical stresses in the material.
For Billy tabletop inserts, which are typically made of medium-density fiberboard (MDF) or particleboard, the front edge can deform slightly due to load or temperature/humidity fluctuations. This causes friction between support surfaces or at connection points.
Important:
- Check whether there are spacer pads or cushions between the front edge and the base structure to prevent direct rubbing.
- Do not use oils or waxes on melamine-coated surfaces without testing first, as they can damage the surface.
A targeted and safe option is to slightly loosen the wooden strips at the front edge and add felt or rubber pads to mechanically reduce the friction.
draleo
10 Apr 2023 14:01
SUBEN60 schrieb:
Important: Check whether there are any spacers or cushions between the front edge and the substructure that might prevent direct contact and rubbing.
This is a key point. Another common mistake is that the top piece does not rest fully and evenly on the lower furniture panel. This leads to rocking movements that cause slight friction.
My advice:
- Make sure the tabletop rests precisely without any play forward or backward.
- If needed, use small felt pads between the top piece and the tabletop; these can significantly reduce noise and friction.
Finally, locating the cause helps by moving and observing the top piece under load to see exactly which areas come into contact.
Z
zarHenning
10 Apr 2023 16:29
Loose screws are often the cause. Simply tighten all the controls.
Then: clean the front edge with a dry cloth, and if needed, rub a little beeswax over it afterward.
This usually works.
