I wonder why assembling Malm furniture can sometimes be so complicated. The instructions are included, but they are often unclear and some steps are quite confusing. Also, the parts don’t always seem to fit perfectly, which can make the assembly a real test of patience, especially for less experienced people.
Does anyone have experience or tips on why this happens? Is it due to the furniture design, the included tools, or something else?
I would like to understand why there are so many reports of difficulties, even though the furniture is actually quite popular.
Additionally, I would like to point out that the Malm product line often relies on very thin wood-based panels and identical components due to its simple design.
Although this construction method is cost-effective, it can result in imprecise fitting. A particularly common issue during assembly is correctly aligning the back panel and the upper crossbars, which can cause difficulties even with slight deviations.
Furthermore, the screw sizes sometimes differ only slightly, and using the wrong screw can damage the piece.
My recommendation: Before inserting the screws, carefully check and compare the parts. If possible, have a second person verify to avoid mistakes early on.
A question for georgesu: Which exact Malm variant do you have, and have you tried using the instruction manual digitally as a PDF? Sometimes additional notes are visible in the online versions.
GOLO42 schrieb:
My recommendation: Be sure to carefully check and compare the parts before inserting the screws.\Thanks for the detailed explanation! I have the simpler 3-drawer model with wood finish. I’m actually using the manual digitally, but I don’t always find the perspectives in the pictures clear enough.
In response to your question: No, I usually do this alone, without a second person. Maybe that’s part of the problem. I’ll wait and see if I can find someone to help soon—I think that could make things a lot easier.
georgesu schrieb:
I usually do it alone, without a second person.Of course, you can manage alone, but having a helper usually boosts morale, and it really makes a difference when holding and aligning.
I once had a problem with a Malm wardrobe where I had to repeat a step because I hadn’t looked closely enough. So you’re not alone with experiences like that. 😉
My advice: take a break now and then, stand up, breathe, and look again with fresh eyes. You often notice things you didn’t see before. 🙂
Elodie schrieb:
I once had a problem with a Malm wardrobe where I had to repeat a step...Exactly, and that brings me to the topic of numbering the components. Ikea does try to label the parts clearly, but from my own experience, I recommend checking all parts individually and comparing them with the list before assembly. A small mix-up can lead to a lot of extra work.
