ᐅ Why is assembling Ikea Hemnes furniture so challenging for some people?
Created on: 4 Nov 2021 09:37
puribau
puribau
4 Nov 2021 09:37
Hello everyone, I recently bought the Ikea Hemnes wardrobe and wanted to assemble it myself. I noticed that the assembly seems quite difficult for many people – there are often reports of problems or frustration in various forums.
I am specifically interested in why the assembly of the Ikea Hemnes is so challenging for some. Is it due to the instructions, the assembly hardware, or perhaps the design itself? Are there common pitfalls during assembly that are not immediately obvious?
I think it is important to understand the issue more precisely in order to give targeted advice later or to plan the assembly better. Who has experience with this? I would especially appreciate tips on how to avoid common difficulties or what to prepare in advance when starting the assembly.
lorena
4 Nov 2021 14:04
puribau schrieb:
I’m specifically interested in why assembling the Ikea Hemnes is so difficult for some people.
The Hemnes can be quite challenging for some users for several reasons. First, although the instructions are generally clear, they assume that all component groups are correctly sorted and that you understand how they fit together. Even small mix-ups with screws or wooden parts can cause problems later on.
Additionally, the construction with plywood back panels and many dowels can be somewhat fiddly. The back panels rarely fit in easily, especially if the cabinet frame is already partly assembled. This can be a real obstacle for those who are less experienced.
Another tricky aspect is the partially asymmetrical design. Many parts look similar but are not identical – you need to pay close attention to the numbering of the components, otherwise everything will end up fitted incorrectly.
I would also recommend unpacking and sorting all components completely before starting, checking the small screws against the instructions. This saves a lot of time and frustration. The Ikea-provided Allen key usually suffices as a tool, but for extra force when assembling, a rubber mallet can be helpful.
Are there specific assembly steps where you’re getting stuck? That way I could offer more targeted advice.
flo-Theres
5 Nov 2021 10:23
lorena schrieb:
Many components look similar but are not identical – you need to pay close attention to the numbering of the parts, otherwise everything will be assembled incorrectly later on.
This is a very important point. The similar appearance of the boards often causes mistakes that only become apparent late in the assembly process.
Additionally, I often see that people do not follow the sequence in the instructions exactly. In the Hemnes series, the order of steps is deliberately designed to gradually secure stability. Skipping steps or forcing parts together too early can lead to permanent problems because the furniture will not fit properly.
My advice is to always read the instructions fully and patiently, and not to skip any steps – even if some of them seem unnecessary at first.
This helps to avoid frustration and rework.
bulanau
6 Nov 2021 07:48
puribau schrieb:
Are there common hidden pitfalls during assembly that are not obvious at first glance?
Absolutely, these hidden challenges are exactly what make the Hemnes difficult for many people.
Here is a brief guide that can improve your planning and execution:
- Preparation: Thoroughly sort all parts and lay them out in an organized way according to the pictures and labels.
- Back panels: Make sure to install these only once the main frame is as stable as possible, otherwise it gets tricky.
- Dowels: Lightly grease them before inserting to make assembly easier.
- Screw connections: Don’t fully tighten all screws immediately. First tighten them all loosely, then gradually tighten step by step.
- Additional tools: Besides the included Allen key, a cordless drill with a torque limiter can be very helpful.
Common mistakes include incorrect orientation of parts, which leads to doors or drawers not fitting properly. If you have more details about your issues, I’m happy to provide specific feedback.
