ᐅ Why don’t some BILLY doors fit perfectly on the shelves?
Created on: 5 Jul 2023 14:23
nelen69
nelen69
5 Jul 2023 14:23
Hello everyone, I recently purchased a Billy shelving unit and ordered matching doors, but I found that the doors do not fit the shelves perfectly. Specifically, they are sometimes slightly too wide or too narrow in certain areas, so they don’t close flush or occasionally get stuck. Are there known reasons why some Billy doors do not fit shelves exactly? I’m not just referring to minor manufacturing tolerances but also factors like different material expansions or production batches. Does anyone have experience with what should be checked or considered in advance to avoid buying the wrong size or to adjust the doors optimally?
CARLA
5 Jul 2023 15:07
nelen69 schrieb:
Are there known reasons why some BILLY doors don’t fit the shelves exactly?
Basically, the dimensions of BILLY shelves and their doors are based on certain standard sizes. However, manufacturing tolerances in wood-based materials and fittings are quite common. Wood can also expand or contract slightly due to moisture, which can lead to fitting issues.
Additionally, different production batches may vary slightly. If doors from one batch are fitted to a shelf from another, this can cause inaccuracies. Incorrectly adjusted or overtightened hinges often also cause mechanical fitting problems.
My tip: Before assembly, carefully check both the actual shelf dimensions and the door dimensions. If necessary, doors can be slightly modified or suitable hinges chosen that allow individual adjustment.
Ramon4
5 Jul 2023 16:51
Hello nelen69, I am very familiar with this issue and can confirm that the interaction between material properties and installation is often crucial.
This problem mainly affects engineered wood products like MDF or particleboard, which are used in the manufacture of BILLY. Depending on the room’s humidity, the material changes its dimensions slightly. This can affect the fit.
Additionally, the door hinges on BILLY are designed to be adjustable. This helps to compensate for minor differences. Still, proper installation is essential to avoid misalignment or improper closing.
Another factor is the wall where the shelf is placed – if it is not completely straight or precisely installed, it can cause the doors to warp. I recommend checking with a spirit level to ensure the shelf is perfectly vertical before installation.
KNUTGI
5 Jul 2023 18:16
Hey nelen69, I’m familiar with the issue of BILLY doors from my own experience! 😅
nelen69 schrieb:
the doors don’t fit perfectly on the shelf
This can be due to several factors: For example, the material may be slightly warped – even the packaging can introduce some moisture. A good trick is to leave the doors in the room where they will be installed for a few hours before assembly. This allows them to adjust to the room’s humidity.
Also, pay attention to the screwdriver setting when installing the hinges. Often the screws are tightened too much, which can cause the doors to stick or not close completely.
A small tip: A bit of patience when adjusting usually helps more than measuring everything precisely or sanding down parts. A careful touch and the right turn on the hinge can work wonders. 🙂
daalessio
6 Jul 2023 09:45
Ramon4 schrieb:
The door hinges on BILLY are adjustable and help to compensate for minor variations
That is correct. Additionally, it should be noted that BILLY shelves and doors are not manufactured as high-precision industrial-grade furniture systems, but as standardized, affordable furniture with certain manufacturing tolerances.
The manufacturer typically specifies tolerances of a few millimeters in the dimensions. These are due to production and need to be compensated for by the end user through adjustments.
Another important point is the assembly instructions: closely following the sequence for screw installation and hinge adjustment is crucial for a perfect fit. Over-tightening during assembly can impair the functionality of the hinges.
Overall, it is advisable to plan for some play and rework before purchase to properly fit the doors to your shelving unit.
Luciandi
6 Jul 2023 10:38
I think this topic clearly shows that buying furniture is often more complicated than it seems.
KNUTGI schrieb:
Store the doors in the room before installation to allow them to adjust to the humidity
That sounds quite reasonable. I had doors myself that were installed immediately after purchase and then caused sticking issues – after a few days in the room, the problems almost disappeared.
Sometimes the production date also makes you nervous: if doors and shelves come from different batches, it can lead to frustration. That’s why I understand nelen69’s concerns here.
But it’s important not to take it too personally, because minor imperfections or adjustments are just part of BILLY furniture. Not perfect, but manageable with some patience.
Maybe exchanging experiences within the community will also help – who knows if there are specific types of hinges that fit better?
