ᐅ Why Don’t MALM Replacement Parts Always Fit Together?
Created on: 5 May 2023 08:13
funeo
Why do IKEA Malm replacement parts sometimes not fit together properly, even though they are supposed to be for the same piece of furniture? I have repeatedly experienced that replacement parts sent, such as drawer fronts or handles, do not fit correctly or the drill holes do not align, despite the model designation. Officially, these parts should be compatible, right? Are there different production batches, manufacturing tolerances, or has IKEA made design changes during the product line’s development that customers can hardly notice without special guidance? It would be helpful to understand why these fitting issues occur, especially when a complete new purchase is not planned.
toril
5 May 2023 11:52
From a technical perspective, the different manufacturing locations are also a factor. IKEA produces in various plants worldwide, using similar but not identical materials and technologies. Dimensional variations can also result from different quality control procedures. Officially, there are target dimension series, but the customer market for spare parts is not the primary focus segment at IKEA, which explains the inconsistencies. For spare part procurement, I recommend providing the original part number and, if possible, the year of production.
derrick34
5 May 2023 12:15
PLOMA schrieb:
that a part from 2017 often doesn’t fit a piece of furniture from 2022 without modifications
Exactly. Old and new batches are not compatible. Therefore, reworking is standard for Malm.
PeoDaniel
6 May 2023 08:04
In case it helps: Some time ago, I ordered replacement parts for my MALM dresser and noticed that the drawer fronts had been slightly modified, especially the drill hole positions were different. I still installed the front but had to drill new holes. This seems to be a known issue with MALM, and IKEA often recommends adjusting parts before installation. Unfortunately, you have to expect this if you don’t have original parts from the exact same production batch.
te-min
6 May 2023 08:59
A tip: If the replacement parts do not fit, simply ask customer service specifically for parts from the same serial number or production phase. This significantly reduces discrepancies.
sinhau
6 May 2023 10:20
Charles schrieb:
not always purchased individually, but sometimes only supplied in sets
This can sometimes lead to confusion when ordering a single part separately. That is why I recommend carefully checking order lists and product details. With MALM, you should not rely solely on the product name but pay close attention to the exact item numbers, which I found myself in the online catalog.
PLOMA
6 May 2023 11:45
For precise identification of the cause:
The manufacturing processes at MALM are designed such that various tolerances accumulate. For example, if there is a deviation of ±0.5 mm (±0.02 inches) in the production of the particle boards, square shifts in the drilling holes, and slight variations in the assembly hardware, then combinations that are newly assembled often are not compatible without additional adjustments. This additive tolerance chain can lead to fitting inaccuracies that are not covered by simple standards.
My suggestion to funeo: Could you please check the production years of your furniture and the spare parts? That would help to better determine the cause.
