ᐅ Why don’t the measurements of my IKEA PLATSA match those in the assembly instructions?
Created on: 29 Dec 2023 18:17
Madra38Hello everyone,
I recently bought the IKEA Platsa wardrobe and noticed during assembly that the dimensions of the wardrobe do not match the specifications in the manual once assembled. Specifically, the carcass measures about 2 cm (1 inch) less in width at the indicated point than stated in the instructions, even though I followed them precisely. This is particularly problematic because I want to fit the wardrobe into an alcove that is tailored exactly to the specified dimensions.
Does anyone have an idea why this discrepancy might occur? Could it be due to manufacturing tolerances, or can the dimensions change during assembly? I aligned the parts carefully and tightened the screws firmly, but it still doesn’t fit.
I would appreciate any tips on how to better understand or fix this issue without having to completely disassemble the wardrobe.
Hello Madra38,
to precisely understand the difference in the measurements, I recommend the following steps first:
- Check whether you have installed exactly the cabinet parts specified for your model, as PLATSA offers various elements with similar dimensions.
- Make sure all boards lie flat against each other without any unintended offsets.
- Keep in mind that the measurements given in the instructions are often ideal measurements taken under optimal assembly conditions, and manufacturers typically allow production tolerances of up to 2 millimeters (0.08 inches) per part.
- Screwing can cause slight warping of panels, which especially affects the total width.
If you have already measured the dimensions yourself, it would be helpful to know exactly which parts of the instructions you are referring to, and whether the measurements were taken from the outside or the inside edge of the construction.
Finally, it is important to know whether you are planning a precise fit into a recess or if there is some leeway available. Especially in built-in installations, a difference of just one millimeter (0.04 inches) can be crucial for positioning.
Madra38 schrieb:
Could there be manufacturing tolerances, or can the dimensions change during assembly?Yes, exactly. Manufacturing tolerances for IKEA cabinet parts usually go up to 2 mm (0.08 inches), sometimes a bit more. Additionally, there are slight variations caused by screws and tensioning. Especially with a system like PLATSA, which is often used in modular form, these deviations should be taken into account.
Hello Madra38,
I understand that such a discrepancy can be frustrating when measuring a niche precisely. To get to the bottom of the issue, I recommend the following:
- Measure the individual panels and components carefully before assembly and compare them with the official dimensions.
- Check the alignment during assembly, as panels can sometimes shift slightly.
- Keep in mind that measurements can vary depending on the method used. External edges, internal dimensions, or center measurements may differ.
Sometimes the floor or an uneven surface can also cause problems during assembly, especially when sliding and aligning parts. A spirit level and a flat surface can be very helpful during installation.
If you like, I can also give you tips on the best measuring points and tools to use for measuring the PLATSA to avoid discrepancies later on.
In summary:
- The measurements given in the instructions are often approximate values, provided without accounting for tolerances.
- Manufactured furniture components each have small production tolerances that can add up.
- The installation process itself can cause deviations due to tension or incorrect alignment.
One possible solution is to make minor adjustments on site or slightly enlarge the niche, if possible. For an exact fit, a custom-made furniture piece or post-processing by a carpenter should be considered.
