ᐅ Why does the Malm bed wobble even though it is secured to the wall?
Created on: 5 Apr 2015 08:34
Jerowan
Jerowan
5 Apr 2015 08:34
Hello everyone, I recently bought a Malm bed from Ikea and, following the instructions, I attached it to the wall to increase stability and prevent wobbling. However, despite the wall mounting, I still notice a noticeable wobble, especially when I turn or sit on the bed.
I have checked all the screws again; they seem tight, and the wall mounting is correctly installed. The wall itself is solid, so that shouldn’t be the issue.
I’m curious about what other factors could cause a properly assembled Malm bed to wobble, even though it should be stabilized by the wall attachment. Could the problem be related to the bed’s construction, the slatted frame, or perhaps there are hidden weak points in the assembly?
Looking forward to your ideas and experiences!
RUBEN54
5 Apr 2015 09:15
Hello Jerowan,
first of all, good question. I often come across the issue of the "Malm bed frame wobbling despite wall mounting."
1. First, check the connection between the bed frame and the slatted frame: often the slatted frame is not seated tightly enough or has some play, which allows movement.
2. It is equally important that the screws into the wall are not only tight but that the anchor and the wall itself properly support the weight. Sometimes the wall panel or the type of anchor used is insufficient.
3. The wall mounting of the Malm bed is actually intended more as a tipping protection rather than the main stabilizer. To eliminate wobbling, the bed frame itself must be mounted very securely.
4. A common mistake is an uneven or slightly tilted wall or an uneven floor. This can also cause visible wobbling even when all screws are tight.
Summary: For the Malm bed, I would also check the slatted frame support points, possibly add extra plastic or felt inserts, and especially have a second person simulate movements during testing to identify where any play occurs. The strength of the wall mounting is often overestimated.
Good luck, feel free to get back with more details!
benonon
5 Apr 2015 11:42
Hello Jerowan,
I would like to address your issue in detail to help you as best as possible.
The wobbling despite the wall mounting can have several causes that should be considered from a technical perspective:
1. Material flexibility: The Malm bed is made from particleboard, which has a certain amount of elasticity. Even when firmly screwed to the wall, the material can still flex slightly.
2. Type of fastening and load distribution: The original wall mounting is a simple tilt lock secured with two screws on each side, which prevents the bed from tipping but does not inherently stabilize it against horizontal or vertical forces. This can allow microscopic movements to occur.
3. Uneven flooring: If the floor is not completely level, the bed may vibrate under load even if the wall mounting is secure. The screws used in the bed cannot fully absorb these vibrations.
4. Assembly of individual wooden parts: Incorrect or loose assembly at connection points (for example, brackets beneath the bed) can cause movement at these spots. You may have overlooked this, as the focus is often on the wall mounting.
5. Slatted frame or mattress support: A slatted frame that does not fit properly or is broken, or a mattress that distributes weight unevenly, can also increase movement.
6. Age of screws and thread locking: It is possible that no threadlocker was used or the screws were not tightened enough during the initial installation. Loosening and retightening the screws with new threadlocker can work wonders.
Could you please describe in more detail how your wall mounting is installed? Did you use the original anchors and screws? What is the condition of your floor? Information about your mattress and slatted frame would also be helpful so we can rule out or confirm these factors.
I look forward to your reply and can then assist you more specifically!
Ryder35
6 Apr 2015 07:27
Jerowan schrieb:
...bought a Malm bed frame from Ikea and installed it on the wall according to the instructions... despite attaching it to the wall, I still notice a noticeable wobble in the bed...
This suggests to me that either the floor is uneven or the slat supports are not properly secured. Wobbling in the bed frame is usually fixed by placing felt pads or shims under the legs or by repositioning the slatted base.
biel33
6 Apr 2015 10:03
I completely understand how frustrating it can be when a new bed wobbles, even though you’ve done everything correctly. 🙂
It’s really annoying when you’re looking forward to your bed and something like this happens. I had a similar situation myself, and it turned out that some screws on the inside weren’t tightened enough—I didn’t even notice it at first.
Maybe you could double-check whether all the connection points on the frame are really secure and free of any play? Sometimes it’s not the visible screws on the wall mount but smaller connections under the bed that cause that slight movement.
Keep your spirits up; this problem can definitely be fixed! We’re here to find solutions together.
Ixvin
7 Apr 2015 15:19
Hello Jerowan,
I would like to summarize and consider what, in my opinion, could specifically cause your Malm bed to wobble despite being secured to the wall:
- As mentioned before, the wall fixture is not designed to make the bed completely rigid. Its main purpose is to prevent the bed from tipping over.
- Be sure to check that all screws in the bed frame are properly tightened. Sometimes a loose connection is not immediately noticeable during assembly.
- The slatted bed base must fit firmly; many models have semi-circular or round support points, which can wobble slightly due to movement.
- Check whether your floor is perfectly level. The Malm frame does not always sit optimally if the floor is uneven.
My recommendation: Try to feel with your hand at each joint where the movement is coming from. If possible, assemble the bed on your own without the mattress, and also preferably without the slatted base, to test the actual frame stability.
Maybe this helps you as a test to find the exact weak point.
