Hello everyone, I have a question that has been on my mind for some time: Why does the IKEA Malm bed creak under load? I have noticed that the noise always occurs when I move on it or sit down, basically when it’s under stress. The creaking is quite annoying, and I suspect it might be related to the construction or the materials used. I am especially interested in the mechanical processes that cause this noise, as well as possible reasons such as material friction, loose screws, or other technical details. Does anyone know about this issue and can explain exactly what causes it and how to permanently fix the creaking?
The squeaking in a Malm bed under load can have several causes, which I would like to explain in more detail here. Generally, the noise often results from friction between moving or poorly secured parts. In a bed like the Malm, this mainly involves the connections between the side panels, the cross slats, and the slatted frame.
A common factor is the loosening of screws or dowels, which allows small movements between the wooden parts. These tiny micro-movements then create friction that is heard as squeaking. Due to the material, particleboard—used for many furniture parts—can also cause noise if it deforms slightly or shifts against other parts.
Besides the mechanical aspect, the surface quality also plays a role: rough or untreated areas produce more noise than sanded, possibly oiled, surfaces. A good troubleshooting method is to first fully tighten all screws, then apply lubricant to the screws and wood joints—for example, silicone spray or beeswax.
It is also interesting to note whether the squeaking occurs under a specific load, such as when sitting on the edge, since this is where the bed is particularly stressed and tension can build up. Have you already checked if all screws are tight and if the slatted frame is properly positioned?
In short: The bed squeaks because small movements and friction occur at the joints when under load—usually due to material properties and assembly tolerances. The exact cause in your bed could be narrowed down with more detailed information.
Palenar schrieb:
The squeaking in a Malm bed under load can have several causesFrom my perspective, the point about pressure distribution is also very important. In IKEA beds like the Malm, the slatted frames and supports are often designed to allow a certain degree of flexibility. Especially if the slatted frame does not sit perfectly or the connections have even minimal play, this immediately leads to movement under load. These movements then cause squeaking due to friction.
I recommend paying close attention when tightening the screws to ensure that the torque is applied evenly and no overstressing occurs. Rubber buffers or felt pads at the contact points can also significantly reduce the noise.
It is also important to check whether the bed base is level—uneven floors create additional stress in certain areas. This can also increase squeaking. Sometimes, simply using appropriate washers or mats can help.
Ah, the classic Malm squeak – almost as well known as the sounds you get when trying not to move while your partner is asleep 😉
Jokes aside: The squeaking usually comes from tiny movements between the wooden boards or at the screw connections. Think of it as a little concert of wood and metal playing under stress. My tip: Gently massaging some baby powder or talcum powder into the screw joints can fix the problem, as it reduces friction without lubricating.
If you find any loose parts, tightening them won’t hurt – the bed should stand firm so the wooden parts rub against each other as little as possible.
And yes, also check the slatted frame sometimes; if it’s not sitting properly, it can cause a bit of “music” when moving around 😉 Good luck!
Palenar schrieb:
…the loosening of screws or dowels, causing small movements between the wooden parts.I believe this explanation is correct, but somewhat simplistic. IKEA furniture is known for efficient yet often cost-saving construction methods. Especially under heavy load, like with a bed, using particleboard and thin screws is basically a recipe for these kinds of issues.
So why not contact the manufacturer directly about a potential material or design flaw? Perhaps the typical Malm creaking is not just wear and tear but a fundamental weakness in the design.
This could be seen as an opportunity to demand more durable, stable materials—maybe even consider choosing a manufacturer with better quality in the future.
What’s your opinion: Is the creaking less of an assembly issue and more a symptom of minimal use of high-quality wood and proper joining techniques?
