ᐅ Why does the glue often come off at the edges of Malm furniture?
Created on: 13 Jul 2021 09:12
NAR-SIEUR
Hello everyone, I have a question that has been on my mind for some time regarding my Malm furniture, and I’m hoping for well-informed opinions here in the forum: Why does the glue often come off at the edges of Malm furniture?
I have noticed that specifically at the visible edges, the veneer or laminate tends to peel off, even though the furniture is otherwise in good condition. Could this be due to the quality of the adhesive, or is it more a result of moisture, temperature changes, or mechanical stress?
I would like to understand whether this is a fundamental issue with Malm furniture or if I might be doing something wrong in terms of care or assembly. Thanks in advance for your insights and tips!
edisondan13 Jul 2021 12:43faso31 schrieb:
Are there specific data on the types of adhesives used and their long-term performance in Ikea Malm?There is hardly any reliable information from official sources, as Ikea focuses less on technical transparency.
However, material tests from independent studies show that EVA and other hot-melt glues, commonly used in affordable furniture, quickly show signs of aging when exposed to moisture and heat.
These are therefore established but relatively basic adhesives that noticeably deteriorate under heavy use.
NAR-SIEUR14 Jul 2021 08:06Thank you for the many responses so far. To summarize, I now see the problem as follows: Ikea uses inexpensive EVA adhesive and foil material with different thermal expansions for Malm, which can delaminate due to moisture, temperature, or stress.
However, manufacturing tolerances and insufficient surface preparation could also play an important role.
Is there a way to ensure improved edge finishing or alternative materials when buying new, or is this generally not available for Malm? Are there any known tips or alternative products on the market that look similar but have better quality?
NAR-SIEUR schrieb:
Are there any well-known tips or alternative products on the market that look similar but are of better quality?Yes, if you are willing to spend a bit more, you can consider solid wood furniture or options with real wood edges, which are much more durable.
Alternatively, you could choose brands that use PUR or polyurethane adhesives, which last longer and are more flexible.
If using Malm furniture, I recommend refinishing it with high-quality edge banding and specialized furniture glue to extend its lifespan.
Sebastianm14 Jul 2021 09:22Re-gluing often helps. Simply use a good adhesive and carefully press the area. This usually holds for several years again.
sebastianm schrieb:
Re-gluing often helps.Exactly, and act quickly at the first sign of detachment, don’t wait. The larger the detachment, the more difficult the repair becomes.
I believe it is important to also consider the frame. Malm represents an affordable furniture concept based on mass production. Quality inevitably suffers.
If the glue comes off at the edges, this is symptomatic of the entire IKEA value chain. In my opinion, if someone wants durable furniture, they need to look elsewhere.
