ᐅ Why does my Malm bedside table squeak when I open it?
Created on: 4 Feb 2021 20:43
boru33
boru33
4 Feb 2021 20:43
Hello everyone, I have been having an issue for a while with my Malm nightstand from IKEA: every time I open the drawer, it squeaks quite loudly. This happens regardless of whether the drawer is full or empty. Otherwise, the nightstand feels solid, nothing is visibly loose or sticking. Does anyone here know what might be causing this? Could it be due to the drawer design, the drawer slides, or perhaps the assembly? I would like to understand the exact cause of the squeaking and how to fix it without damaging anything. Thanks for your advice!
moses
4 Feb 2021 21:17
That sounds really annoying. I also experience squeaking with furniture at home, especially with older or simpler models.
boru33 schrieb:
Could it be related to the drawer design, the runners, or maybe the installation?
These are often the main causes. For Malm nightstands, IKEA frequently uses basic metal or plastic runners that can wear out slightly or become misaligned over time. Dust or small debris in the runners can also increase the squeaking noise.
I would suggest carefully removing the drawer completely and checking the runners for any buildup. Sometimes a drop of lubricant can help, but be cautious because too much oil can attract dust. Hopefully, someone with specific experience regarding Malm drawers will chime in. Don’t worry, this problem is usually quite easy to fix.
Domau0
5 Feb 2021 09:08
The squeaking noise from your Malm nightstand most likely comes from the sliding rails, specifically due to friction between the moving parts. IKEA usually uses plastic runners that glide directly on metal profiles. Over time, the lubrication can wear off or dirt can accumulate, causing this unpleasant sound.
You can try the following steps:
1. Completely remove the drawer to gain easier access to all components.
2. Thoroughly check the guides for dust, small stones, or lint and remove them using a brush or compressed air.
3. Clean the sliding rails slightly, for example with a lint-free cloth.
4. Use a suitable lubricant. Silicone sprays or dry lubricants (such as graphite powder) are recommended. Oil-based lubricants can attract dust and make the problem worse.
Important: When reinstalling, make sure all parts are correctly positioned and screws are not over-tightened to avoid stress and deformation.
Have you already tried removing the drawer system? If so, what did you notice? That could help to further pinpoint the issue.
BELLA34
5 Feb 2021 19:41
Domau0 schrieb:
That causes this unpleasant noise.
Exactly. The best approach is to clean the tracks, apply silicone spray, and reinstall the drawer. The squeaking should stop.
