ᐅ Why does my Malm bedside table squeak when it’s moved?
Created on: 4 May 2021 08:23
U
Usratko
Hello everyone, I have a Malm nightstand from IKEA that has been squeaking with every movement for some time now. The noise is relatively high-pitched and occurs both when slightly moving it on the floor and when opening and closing the drawer. The construction mainly consists of fiberboard with a thin layer of lacquer. I suspect that friction between certain parts is causing the squeaking, but I’m not sure where to start first. Has anyone had similar experiences or can explain exactly what causes the squeaking and how to fix it permanently? Thanks in advance for any helpful tips!
Jorgela
4 May 2021 12:15
In short: Properly tighten the screws, clean the drawer slides, and treat them with silicone spray. If that doesn’t help, stick thin felt pads on the contact points between the drawer and the cabinet body.
Palenar
5 May 2021 08:05
The cause of the squeaking could also be related to the furniture legs. Malm nightstands often have small plastic glides or felt pads under the feet, which can become damaged or worn over time. When moved on hard floors, squeaking or creaking can occur due to tiny shear movements.
I recommend the following steps:
1. Check the glides on the bottom of the furniture legs for damage.
2. Replace them with new felt pads or rubber bumpers if necessary.
3. If the floor is uneven, this can increase stress on certain connection points.
Could you please briefly mention what type of flooring your nightstand is standing on? Laminate, hardwood, carpet? This information would help provide a more precise diagnosis.
U
usbla
5 May 2021 08:38
Usratko schrieb:
What type of wax would you recommend for furniture? Are there differences, for example, in terms of compatibility or durability?
For your purpose, natural beeswax or special hard wax for furniture is ideal. These waxes are durable, do not leave sticky residues, and provide additional surface protection. Most hardware stores carry furniture hard wax in stick form or liquid – the stick type allows very precise application.
Baby powder is a quick, practical tip, but its residues can build up over time, which is not ideal. For a long-lasting solution, I recommend hard wax and possibly silicone spray.
kibutar
6 May 2021 10:17
FLONE41 schrieb:
Sometimes such noises are also a sign that the furniture is slightly “working” or adapting to the surrounding conditions
This is an important point. Wood-based materials react to moisture and temperature changes by expanding or contracting. If the particleboard is under slight tension, this can increase friction and cause squeaking.
I would therefore recommend checking the indoor climate conditions. A moisture meter can provide insight – ideally, the relative humidity and temperature in the room remain stable in the mid-range (about 40–60% humidity, around 20°C (68°F)).
If the air is too dry (such as heated air in winter), a humidifier might help reduce tensions in the wood.
What are the conditions like in your environment?
