ᐅ Why does my BILLY bookshelf wobble even after being secured multiple times?
Created on: 2 Jul 2023 08:23
JUVENAL36
Hello everyone, I have an IKEA Billy bookshelf that I have attached to the wall multiple times exactly as described in the instructions. However, it still wobbles noticeably, especially when I apply light pressure to the top edge. The bookshelf is standing on a level floor and is not overloaded. The fasteners were installed with the supplied plugs and screws into a solid wall. My question is: Why does my BILLY bookshelf continue to wobble despite multiple correct attachments, and what can I do to truly improve its stability?
Hello JUVENAL36,
I’m happy to help: BILLY shelves are generally built quite lightly to stay flexible. When mounting on a wall, you should make sure the screws are really anchored deep and firmly into the wall. Slightly adjusting the drilling depth or the size of the wall plugs can make a big difference here.
Also, definitely check the back panel, as others have already mentioned. If the back panel does not fit perfectly flat or is even warped, this significantly reduces the stability.
Sometimes the problem is very simple: a minimal diagonal misalignment of the shelf can cause it to wobble. Try checking the shelf with a spirit level on all planes (vertical and horizontal).
If you could tell us the exact wall type (concrete, brick, plasterboard, etc.) and the floor condition, I can give you better tips.
JUVENAL362 Jul 2023 17:30Thank you for your detailed responses; that already helps a lot! I have a few more details about the shelf:
- The back panel is simply slotted in and fixed with small nails. I could reinforce it further.
- The floor is laminate but appears to be level.
- The wall is solid brick masonry.
- The fastenings are installed with impact anchors and appropriate screws, which I carefully checked using a drill and measuring tools.
My thought is that the wobbling might come from the construction of the shelf itself. Do you have any tips on how I can internally stiffen the shelf? I am also open to minor modifications.
JUVENAL36 schrieb:
My guess is that the wobbling might come from the construction itself.That’s quite possible. A BILLY without a sufficiently rigid back panel easily loses stability because the side panels don’t provide enough resistance against tipping and shear forces. My suggestion:
1. Replace the original thin back panel with a slightly thicker MDF board, which you screw onto the back. Alternatively, you can attach cross braces on the back to make the structure especially stable.
2. Consider installing a diagonal brace running from one bottom corner to the opposite top corner. This will significantly improve resistance to shear forces.
3. Also check that all screws in the shelving unit, especially at the corner joints, are tight. You might want to slightly pre-drill the holes and secure the screws with wood glue.
These measures usually help eliminate wobbling. Do you have experience with basic woodworking, or would you need detailed instructions?
Domau0 schrieb:
Replace the original thin back panel with a slightly thicker MDF boardI fully agree with that. Additionally: If you want to reinforce the back panel yourself, make sure the board is not too heavy, so the wall mounting isn’t additionally stressed. It’s best to choose an MDF board about 6-8 mm (0.25-0.3 inches) thick and screw it directly to the shelf sides using small angle brackets.
JUVENAL36 schrieb:
I’m also open to smaller modifications.In that case, adding diagonal braces, for example made from flat steel or wooden strips, would be a neat solution. These can be mounted inside on the back panel side and effectively prevent wobbling.
