ᐅ Why does my Billy bookshelf tip over even though it is properly secured to the wall?
Created on: 5 Oct 2023 18:22
Giadra
I recently assembled a Billy bookshelf from IKEA and securely fixed it to the wall using the included wall fasteners. However, the shelf often tilts or sometimes even tips forward when I gently touch it or remove books. I installed the wall fastener in the designated spot, and the anchor is firmly set in the wall.
I am wondering: Why does my Billy bookshelf tip over despite sufficient and proper wall fastening? Are there specific factors—whether related to the shelf’s design, the choice of fasteners, the wall material, or the installation process—that I might have overlooked?
I would appreciate any tips or explanations for this unexpected tipping behavior. Thank you!
GALENKU
6 Oct 2023 10:27
More fixing points at the bottom or in the middle definitely help, as this reduces the tipping moment. The wall will not be overly stressed as long as you do not drill holes too close to each other.
Make sure the wall plugs are suitable for brick and that the drill bit is not too large.
Joe52
6 Oct 2023 21:45
Giadra schrieb:
The drilled holes do seem to be somewhat larger than optimal
Hi, I wanted to add that I have experience with lighter shelving units for relatives: oversized drilled holes are really the classic culprit. I once ignored the problem, and after a light bump, the shelf suddenly tilted significantly.
If only plastic anchors are available, it’s worth switching to heavier metal or chemical anchors when the shelf will bear weight. Especially with solid brick walls, this provided noticeably better support.
First, try the appropriate anchors and additional fastenings. 🙂
Trate47
7 Oct 2023 07:28
Hey Giadra and everyone else,
I really like this thread because it’s refreshing to see not only problems but also good approaches.
Just something to smile about: Sometimes the solution is like a good cup of coffee – that little extra bit of care, materials, or an additional fixing point makes all the difference.
I can only confirm that. A shelf with multiple fixing points simply feels more secure. Also, if you like, IKEA sometimes offers small brackets inside the shelving unit that provide extra support – not officially part of the instructions, but a nice addition.
All that’s left to say: Good luck – your shelf will definitely be stable! 😉
