ᐅ Why does my Billy bookshelf tip over even though it is properly secured to the wall?
Created on: 5 Oct 2023 18:22
Giadra
Giadra
5 Oct 2023 18:22
I recently assembled a Billy bookshelf from IKEA and securely fixed it to the wall using the included wall fasteners. However, the shelf often tilts or sometimes even tips forward when I gently touch it or remove books. I installed the wall fastener in the designated spot, and the anchor is firmly set in the wall.
I am wondering: Why does my Billy bookshelf tip over despite sufficient and proper wall fastening? Are there specific factors—whether related to the shelf’s design, the choice of fasteners, the wall material, or the installation process—that I might have overlooked?
I would appreciate any tips or explanations for this unexpected tipping behavior. Thank you!
Joe52
5 Oct 2023 18:45
Hello Giadra,
I can understand well that such a tilting, despite seemingly proper fastening, is annoying and concerning. I once had a similar problem, and it turned out that the anchors used for the wall really need to be strong. Sometimes the slight tilting is caused by minimal play in the fastenings, which then needs to be reinforced.
Maybe it will help if you check whether the wall fixings are firmly anchored in the masonry and whether the screws themselves provide enough grip. This is especially important for lightweight drywall, where the fixings are often too weak.
Don’t worry, I’m keeping my fingers crossed that you’ll get this under control quickly!
Kinbu
5 Oct 2023 19:13
Hello Giadra,
your description suggests that while the wall mounting is basically in place, the attachment points or the type of wall might not be an ideal match.
Joe52 schrieb:
This is especially true for lightweight drywall, which is often too weak.
I agree with that. Drywall and similar partition walls require special anchors; otherwise, the hold will be insufficient. Another important detail is the number of fasteners: for Billy-style shelves, at least one top anchor is recommended, but sometimes that is not enough if the shelf is loaded with heavy weight over several levels.
Also, check whether the shelf is perfectly vertical and the feet are fully resting on the floor. Even slight rocking at the base affects stability.
If the shelf is on a sensitive floor surface that easily deforms, this can further encourage tipping.
Giadra
5 Oct 2023 19:45
Thanks to both of you for the initial suggestions!
About the wall: It is a brick wall, not a drywall partition. The anchors are the standard plastic anchors from the IKEA set, which, in my assessment, fit well.
Regarding the floor and shelf: I specifically checked with a spirit level; the shelf itself is level, and I also checked the base surface, which has no noticeable unevenness.
I find the comment about the load interesting: Although the shelf is already filled with books, it is not extremely heavy.
I am now wondering if it could be related to the type of fastening – how far the screw extends into the wall, and whether the wall anchor can really prevent tipping at the top edge of the shelf.
Does anyone have experience with mechanical leverage effects on wall fixings for shelves like these?
anfeteo
5 Oct 2023 20:17
Hello Giadra,
I’ll briefly summarize and provide a small checklist for inspection, as this topic can be quite complex:
1. Check the type of wall plugs according to the wall material:
- For brick walls, standard plastic anchors are usually fine, as long as the drill bit is correctly chosen and the anchor fits tightly.
- Loose anchors or oversized drill holes significantly reduce holding strength.
2. Screw length and positioning:
- If the screw is too short, it might not press the shelf firmly against the wall.
- If the fixing point is too low or too high, the shelf can act as a lever.
3. Number of fixings:
- At least one securing point at the top is recommended; for larger shelves, adding one in the middle or at the bottom is advisable.
4. Weight and center of gravity:
- Placing heavy books on the top increases the tipping moment.
5. Floor contact:
- Although you mentioned it fits well, adding an extra non-slip felt pad on the feet can’t hurt.
Also, take another close look at the assembly instructions, especially how the brackets are hung – sometimes a small step that seems harmless can have a crucial impact on stability.
I hope this structured summary helps you!
Giadra
6 Oct 2023 08:03
anfeteo schrieb:
1. Check the type of anchors based on the wall material
Thanks for the clear structure!
I took a closer look this morning: the drill holes do seem a bit larger than ideal, which could affect stability. The anchors are in place but not completely secure.
anfeteo schrieb:
5. Floor adhesion
The feet are standing on laminate flooring, which is a bit slippery. I’ll try adding felt pads; maybe that will make a difference.
A question for the group: If I fix the shelf not just at the top but also in the middle or bottom, will that really help that much? Or is there a risk of putting too much strain on the wall?
Thanks again for the detailed tips, I appreciate all the help!
