Some time ago, I bought a Billy bookshelf from IKEA, and it is now in my home office. Whenever I load the shelf with books or other weight, it creaks at certain points. I’m not exactly sure whether it’s coming from the back panel, the shelves, or the screws, but it only happens under load, not when the shelf is empty.
I am curious why my Billy bookshelf creaks when loaded. Is this normal, or could there be a material defect? Are there any known weak points that can be easily fixed? I have already tightened some of the screws, but the creaking is still there. Has anyone had similar experiences or ideas on how to stop it?
Thanks for your feedback!
Bupokau schrieb:
I think I will first systematically check the screws again and then work with felt stripsThat sounds like a very good plan. It’s best to use a Phillips screwdriver of the correct size to tighten the fasteners evenly and not too tightly – otherwise, the material might even tear. The felt strips provide decoupling of the contact surfaces, which often helps with squeaking noises.
If the back panel is loose, you can additionally secure it with small nails or extra screws. The back panel acts like a diagonal brace – it prevents deformation.
benfa schrieb:
It would be interesting to know exactly how your shelf is loaded and whether it is standing on a completely level floor?Regarding the floor: even small unevenness is often the cause of noises. Placing washers under the feet or making the feet adjustable can sometimes be a helpful solution.
Good luck with that, and feel free to ask if you have any further questions! 🙂
