ᐅ Why does my Billy bookcase feel unstable after a few years?
Created on: 10 Mar 2022 18:07
gokhansa55
gokhansa55
10 Mar 2022 18:07
About six years ago, I bought a Billy bookshelf from IKEA, which I now find quite unstable, even though I have never overloaded it. It starts to wobble, especially when I take something out of or put something into one of the lower shelves, and there is also a slight creaking noise more often. My question is: Why does my Billy bookshelf seem unstable after several years of use, even though it originally felt quite sturdy? Is it likely due to material fatigue, assembly errors, or are there known weak points that develop over time?
So far, I have observed the following:
- I always place the bookshelf on a stable, level floor.
- The weight is evenly distributed, no overloading.
- I don’t use any additional fasteners, such as wall anchors.
Are there any tips for maintenance or retrofitting to restore its stability? Thanks in advance for your help!
Z
zarHenning
10 Mar 2022 18:35
often the reason is insufficient wall mounting. Billy shelves tend to become unstable after a few years if they are not fixed to the wall. You can prevent this by fastening them with screws and wall plugs.
draleo
10 Mar 2022 19:09
zarHenning schrieb:
A common cause is insufficient wall mounting.
This is an important point. The cabinet material is usually made of engineered wood panels, which are exposed to moisture and stress over time. This material fatigue leads to loosening at the joints as well as slight deformations.
Additionally, missing wall mounting significantly reduces stability because the shelf then rests only on the lower connection points and is less able to resist lateral forces effectively.
Therefore, it is advisable to check and tighten the screws and fittings in addition to a temporary solution with wall anchors. Replacing damaged shelves or connecting fittings may also be necessary.
Linavin
10 Mar 2022 20:23
gokhansa55 schrieb:
Why does my Billy bookshelf feel unstable after a few years of use, even though it seemed quite stable at first?
A relevant factor is the construction method: the Billy shelf is not solid wood but made from thin, coated particleboard. Over time, these panels can expand and contract due to temperature and humidity changes.
Additionally, stability is affected both by the direction of the load and the type of joint used. If screws or dowels loosen over time from regular use, this increases the instability.
You mentioned that the shelf was never overloaded, but how evenly was the weight distributed across the shelves? Uneven loading causes stress on the frame. Have you tried repositioning or moving it?
I think an important point is often overlooked here: how well was the shelf assembled in the first place? Minor issues during assembly can become more noticeable over the years.
Rhett
10 Mar 2022 21:12
Wobbling usually occurs due to loose screws or missing wall anchors. Simply tighten all screws and then add wall brackets. This is often enough.
toril
11 Mar 2022 08:48
Linavin schrieb:
How well was the shelf assembled from the start?
This is important because faulty or insufficient assembly leads to premature wear.
Material fatigue in furniture made from wood-based panels occurs due to cyclic stresses that do not have to be severe, but over the years cause small cracks and loosening at the joints.
Even if there is no overload, these effects accumulate and affect the stability.
One way to improve stability is to use additional angle brackets or braces to better absorb lateral forces.
