ᐅ Why do some Billy bookcases develop mold?
Created on: 5 Feb 2023 10:13
lehinrich
lehinrich
5 Feb 2023 10:13
I hope to find experts here who can help me with a rather specific issue: Why does mold develop on some IKEA Billy bookcases?
I have noticed that not all Billy bookcases are affected, only certain pieces—even though they are treated similarly. In some cases, the mold seems to grow mainly on the interior surfaces or in corners that are hard to reach.
I suspect that the material and construction of the bookcase play a role, but environmental factors like temperature and humidity might also be crucial. I am also interested in whether airflow inside the bookcases could be an important factor in mold formation.
Are there any experience-based reasons or technical explanations as to why Billy bookcases, in particular, can suffer from this problem and how to prevent it?
Thanks in advance!
V
vin_leo
5 Feb 2023 14:07
Hey lehinrich,
first of all, great question! Billy shelves are practical and found almost everywhere, but mold? That doesn’t come for free, of course 😅.
I think the typical issue is that Billy shelves are often placed very close to walls that might not be perfectly insulated. The wall cools down from the outside, while it stays warm inside, which causes condensation. This is where mold spores can start to grow, especially in cool corners or behind the shelves.
lehinrich schrieb:
"Maybe the ambient temperature or humidity also plays a decisive role."
You hit the nail on the head there. Especially in winter, when heating and ventilation are on, the wall can get damp — perfect conditions for mold.
My tip: try to keep shelves a few centimeters away from the wall for better air circulation. That way, mold has less chance 🙂
PLOMA
6 Feb 2023 09:41
Good morning everyone,
I would like to explain this topic in more detail, as some technical aspects are often overlooked. Why does a Billy shelf develop mold even though it is made of pressed wood veneer (chipboard with a melamine resin coating)?
First, it is important to know that the material itself is not mold-resistant. When combined with moisture and poor air circulation, a microclimate quickly develops that promotes mold growth. This often happens in areas with poor air circulation, such as room corners, between the back of the shelf and the wall, or on interior surfaces that are rarely ventilated.
vin_leo schrieb:
"the typical problem is that Billy shelves are often placed very close to walls that might not be perfectly insulated."
Exactly, poorly insulated exterior walls cool down in winter, and this is where condensation forms. This condenses especially on cooler spots, such as where the wall surface temperature is low. The water soaks into the chipboard-like materials, which can absorb and hold moisture. Due to the darker, poorly ventilated gaps—often created by the back panel and shelf constructions—the moisture is held long enough for mold spores to germinate.
Ventilation and spacing are two essential factors for prevention. Additionally, it is important to avoid thermal bridges, for example, when the shelf is placed directly on a cold floor or directly against an exterior wall.
As a moisture barrier, special vapor barriers or antifungal coatings on the wall may be considered, depending on the building condition.
Question: Is your shelf located in a room with elevated humidity, such as a bathroom, kitchen, or basement? And what is the wall structure like there?
This information helps to narrow down the cause more precisely.
lehinrich
6 Feb 2023 11:58
Hello PLOMA, thank you for the detailed post!
About the room: The shelf is located in my living room, but directly against an exterior wall that is poorly insulated on the outside. The wall is also quite thin. The indoor air is generally not very humid, and I ventilate daily, but probably not enough during cold weather.
Regarding the distance: The shelf is actually placed flush against the wall, almost tight.
vin_leo schrieb:
"My tip: Maybe always place shelves a few centimeters away from the wall for better air circulation."
I will definitely try that, thanks!
If that is not sufficient: How effective are vapor barriers really? Is it possible to install them later without too much effort?
One more thing: Can poor ventilation inside the shelf itself (e.g., accumulated moisture in the compartments) also promote mold growth? Or is it mainly the wall and exterior conditions that matter?
Nabla64
7 Feb 2023 08:06
Hello lehinrich,
I will try to give a structured answer to your last question.
1. Mold caused by wall dampness: As PLOMA already explained, condensation forms on cool walls. If the Billy shelf unit is placed directly against such a wall, moisture can penetrate the back panel or edges of the particleboard.
2. Air circulation and ventilation: Very important! If a Billy shelf is placed directly against the wall, air exchange is minimal. Moisture that has entered during the day cannot evaporate, so it stays damp.
3. Moisture inside the shelf itself: Air movement is very limited in fully packed shelves. Books and other items store moisture (especially paper), causing humidity levels inside the shelf to rise.
My advice: Place the shelf slightly away from the wall (for example, 2-3 cm (1 inch)), air the room regularly (ideally with quick ventilation), and keep the room temperature around 18-20°C (64-68°F).
There are also special wood varnishes that repel moisture or prevent mold as a precaution. However, you need to choose these carefully to avoid damaging the material.
In short: It is a combination of wall moisture, poor air circulation, and moisture inside the shelf that leads to mold.
V
vin_leo
7 Feb 2023 12:38
lehinrich schrieb:
"If that’s not enough: How effective are vapor barriers really? Can they be installed afterwards without too much effort?"
Hey, vapor barriers are like little superheroes against moisture, no doubt! 😉 But installing them afterwards can be tricky. Usually, they are part of the wall construction and not really meant to be just ‘stuck on’ afterwards.
A good solution is often a combination of improved ventilation and placing shelves with some distance from the wall.
By the way, I once had mold problems behind a Billy shelf too, and setting it up with some space plus regular airing out worked wonders.
Also, sometimes using hard back panels instead of standard ones helps, as they don’t absorb moisture as much.
Good luck with your mold battle! 🙂
