I have a small but annoying issue with my IKEA Billy furniture piece. It creaks quite often, especially when I walk past it or lean on it. Despite regular use, the noise has become quite bothersome. My question is: why does Billy creak frequently, and how can I prevent it?
I suspect it has to do with the construction or the connections between the parts, as I mainly hear the creaking under load. Could it be related to the material or the screws? What specific measures can be taken to reduce or even completely eliminate the creaking? I would appreciate any tips on assembly, lubrication, or repairing any existing damage.
Elias schrieb:
It’s great that you want to understand the cause more precisely before you start doing anything yourself.Thank you for the advice, I agree. I was aware that careless handling could make the problem worse.
Blavin schrieb:
1. Check that screws are firmly seated and tighten them if necessary.I will check that thoroughly. It would be helpful to know whether they tend to loosen again over time or if tightening them once is sufficient.
uslis47 schrieb:
This is not a defect, but normal wear and tear.That reassures me, as I was genuinely worried that there might be material defects.
I appreciate the practical tips and will now try these steps systematically and report back whether they help. 🙂
Here is a brief guide to effectively reduce squeaking:
1. Remove furniture to reduce weight and make it easier to work on.
2. Check all screws with the appropriate screwdriver. Do not overtighten; tighten only until there is noticeable resistance to avoid damaging the wood.
3. At contact points where metal meets wood, carefully apply a thin layer of wax or a special dry lubricant (e.g., Teflon paste).
4. If possible, remove shelves or back panels and clean the surfaces, as dirt can affect the fit.
5. Reassemble the furniture and place it on a level floor.
Usually, this simple maintenance is enough to make Billy squeak-free again. If any fittings are damaged, it is recommended to replace them with identical spare parts. Many issues arise from connections that are either too tight or too loose.
If you have any questions about the process, I am happy to provide a more detailed step-by-step guide.
