ᐅ Why does the beam bend more often under heavy loads?
Created on: 21 Jan 2023 08:17
noamreo
noamreo
21 Jan 2023 08:17
I have noticed that my Billy bookshelf tends to bend repeatedly under heavy loads. Specifically, I am interested in understanding: Why does the Billy bend more often when heavily loaded?
The shelves seem to sag under the weight, even though the bookshelf is designed for the specified maximum load capacity. Is this due to the materials used, the construction, or are there other technical factors that commonly cause this?
I want to understand the exact causes of this behavior in order to either better distribute the load or consider alternative solutions if necessary.
barle
21 Jan 2023 09:03
The Billy shelf is made of particleboard, which can bend under heavy loads. The bending occurs due to the sagging of the shelves. More weight results in greater pressure in the center.
Trate47
21 Jan 2023 09:45
barle schrieb:
The bending is caused by the sagging of the shelves.
Exactly! The shelves act like a thin intermediate support – as soon as you put too much weight on them, the material starts to show its limits. 🙂 Kind of like a wet spaghetti stick, if you know what I mean 😉
Domau0
21 Jan 2023 10:12
To answer noamreo’s question from a technical perspective:
The Billy shelf uses panels made of MDF or particleboard with a typical thickness of about 1.5 to 2 cm (0.6 to 0.8 inches). While these are sufficiently stable for residential use, their bending strength is limited. Under load, the weight is not fully supported by the edges but mainly acts in the middle of the panel, causing what is known as bending deflection.
The moment of inertia of the panel is low, so it deforms under force when heavily loaded. Additionally, factors such as the length of the shelves, the fastening of the support strips, and the use of back panels affect stability.
Have you carefully checked how the load is distributed and whether the shelf is standing on a level surface? Temperature and humidity can also impact the material; MDF in particular tends to swell, which promotes deformation.
liskar
21 Jan 2023 10:58
Additional explanation: The deformation under heavy load occurs because the bending stress on the shelves exceeds the elastic limit of the wood-based materials used.
Often, the allowable continuous load is specified by the manufacturer, but users can effectively surpass this limit through uneven or concentrated load distribution. The specific design of Billy, with thin particleboard shelves without additional cross supports underneath, promotes bending.
To prevent this, it is advisable to distribute heavy items across multiple shelves or to install additional reinforcements, such as metal brackets.
Farmo
21 Jan 2023 11:23
The floors bow mainly due to the missing central beam. When the load is too heavy and centrally positioned, the material cannot generate enough counterforce. It would be better not to overload the shelf.
