Hello everyone, I have an issue with my Billy bookshelf where the connectors keep loosening, even though I assembled them correctly. The bookshelf is placed on a level surface and is not subjected to excessive load. The screws are initially tight, but after a few days or weeks, they loosen on their own, causing the bookshelf to become unstable and sometimes slightly wobbly.
Can anyone explain why this happens? Could it be due to the material, the assembly, or the type of fasteners used? I even treated all the screws with an appropriate thread-locking compound, but the problem still occurs. Is there a way to fix this permanently without having to take the bookshelf apart? Any advice or shared experiences would be greatly appreciated, thanks!
The repeated loosening of connectors in BILLY shelves has systematic causes. The joining technique mainly uses particleboard with cam lock fasteners, which rely on friction and precise fit.
Issues occur when:
- The drill holes are oversized or worn down.
- The material swells or deforms due to moisture.
- The screws are not installed correctly or tightened unevenly.
A practical solution is to reinforce areas near the holes with wood filler or wooden dowels. After the filler has fully dried, reassemble the shelf and tighten the screws evenly. Wall mounting should also help prevent looseness.
Issues occur when:
narDietmar23 Oct 2023 14:07Lotizar schrieb:
The screws were not installed correctly or with uneven torqueThis is a key point. BILLY shelves require a certain consistency when tightening the cam locks. If one side is tightened too much while the other is hardly tightened, it creates stress that can cause loosening.
I also recommend checking the screw heads and cam mechanism for wear. Sometimes the hex sockets or cam locks are slightly worn, so they no longer hold optimally.
Thank you for your helpful comments so far!
Yesterday, I carefully checked all the connections again and noticed that some of the drill holes in the particleboard are actually slightly frayed.
That sounds interesting – how exactly would you recommend doing this without having to disassemble the shelving unit? Or is it necessary to take the whole unit apart? I would have been more inclined to try using some glue or a special insert that can be applied through the drill hole.
Lotizar schrieb:
to stabilize areas near the drill holes with wood filler or wooden dowels
sautar schrieb:
That sounds interesting – how exactly would you implement that best without having to dismantle the shelf?A permanent fixing without dismantling is difficult because cam connectors require tight fittings. If the holes are worn out, it is hardly possible to create a stable reinforcement from the outside.
A workaround would be screws with slightly longer threads and wall plugs in the drilled holes, provided there is enough space. Slightly taking the shelf apart, inserting a suitable wooden dowel joint, and then re-screwing it is, in my opinion, the best way.
BILLY shelves are affordable, which means some material quality is not entirely consistent. A common cause of loose joints is material fatigue due to changing loads and fluctuations in temperature and humidity.
If the shelf is moved regularly or the screws are overtightened, the connection will not hold permanently. My recommendation is to occasionally retighten the connectors after assembly.
