ᐅ Why do Billy bookshelf shelves sometimes not fit perfectly into the brackets?
Created on: 3 Oct 2017 09:43
bugileoHello everyone,
I have noticed that the shelves of the Billy unit sometimes do not fit exactly into the brackets, even though everything appears to be assembled correctly. My question is: Why do the Billy shelves sometimes not fit precisely into their designated brackets? Specifically, when trying to insert the shelves, it seems as if the holes or the brackets themselves do not exactly match the measurements, causing the shelf to either not sit flush or be difficult to slide in.
Does anyone know the common reasons for such discrepancies? Could this be due to material tolerances, assembly errors, or are these fitting issues generally typical for Billy shelves?
I have already checked if the shelves are straight and if the brackets are firmly secured. Still, there always seem to be slight variations. I would appreciate a detailed explanation to better understand whether I am missing something or if I just need to be patient. Thanks in advance!
Hello bugileo,
I can help you with that. Basically, when it comes to furniture like Billy, there are three common reasons why the shelves don’t fit perfectly into the supports:
1. Material tolerances: IKEA produces in large quantities and maintains certain tolerances. The drill holes can be slightly off, which can quickly become an issue with thin top shelves.
2. Assembly deviations: If the side panels are not mounted perfectly vertical or parallel to each other, the holes will no longer line up exactly. This makes inserting the wooden shelf much more difficult.
3. Type of support and load: The plastic supports have some play to allow the shelf to be installed and removed. If the supports slip or are inserted to different depths, this can affect the stability.
My advice: First, check the alignment of the shelves, possibly using a spirit level. Then, make sure all supports are inserted equally deep. If the boards themselves are slightly warped or bent, this can also cause them to sit unevenly.
That’s exactly why I would say it’s more a combination of the points mentioned rather than a general “problem,” but rather a typical manufacturing tolerance that you need to compensate for a bit.
Hope that helps you! 🙂
bugileo schrieb:
"Is this due to material tolerances, assembly errors, or are such fits generally problematic for Billy shelves?"
It’s interesting how everyone obediently talks about “material tolerances” as if that’s a legitimate excuse for poor fit and finish. Honestly: IKEA produces billions of Billy bookcases, so why should the quality—that is, the precision of drilling holes in walls and panels—be worse than other manufacturers?
To me, it sounds more like they deliberately cut corners during production to reduce costs. And customers are then expected to deal with some “play” and “assembly discrepancies.”
Isn’t that a terrible attitude? This turns furniture assembly into a cat-and-mouse game where the customer constantly has to adjust, instead of the shelf fitting together cleanly. I believe the difficulty with fit is even a deliberate setup for additional purchases, since once you start tinkering with the Billy bookcase, you soon consider getting the matching storage boxes or fasteners 😉
My theory: this problem isn’t accidental, but by design. Anyone who asks for more gets “tips” on how to fix the issue themselves, instead of the manufacturer providing a remedy. That way, IKEA stays spotless and the customer stays busy during assembly. What do you think?
tolokau schrieb:
"IKEA produces in large quantities while maintaining certain tolerances."
GALEO4 schrieb:
"Isn't that a terrible attitude?"Thank you, GALEO4, for your assessment; there is definitely some criticism there that I wouldn’t have expressed so openly before. It’s interesting that you mention manufacturing costs and the *deliberate* balance of quality, as that connects directly to the logistics and overall business model of IKEA.
Personally, I tend to favor a mix of acceptable manufacturing tolerances and typical sources of error during assembly. It seems to me that the expectation of a perfect 1:1 fit for a mass-produced product is unrealistic, even though that is unfortunate.
tolokau schrieb:
"If the side panels of the shelf are not installed perfectly vertical or parallel to each other, the holes will no longer line up exactly."This is exactly where I see the biggest challenge for less experienced DIYers: you buy an inexpensive shelf, but the so-called “faults” are already built into the assembly.
My question would be: Are there any good “tricks” to compensate for these deviations when inserting shelves without significantly compromising stability or appearance? For example, certain tools or techniques that make assembly easier?
