ᐅ Why do the back panels of Billy bookcases often come loose?
Created on: 24 Apr 2023 09:17
farcanstanF
farcanstan24 Apr 2023 09:17Hello everyone,
I have been thinking about a problem with Billy shelves from Ikea for some time now, specifically regarding the back panels: Why do the back panels on Billy shelves often come loose?
I mean that the thin back panels, which are usually attached only with small nails or staples, tend to fall out or at least become noticeably loose after a while. This causes the shelf to feel unstable and can sometimes create noises.
I am particularly interested in the mechanical and material-related reasons: Is this a weakness of the material, a design flaw in the attachment method, or do environmental factors like humidity play a significant role?
I have also heard that the assembly can sometimes be incorrect, but I generally follow the provided instructions carefully and take my time during assembly.
Does anyone have experience or explanations for why the back panels come loose so often? How can this problem be permanently avoided?
Thanks in advance for any helpful answers!
Hello farcanstan,
regarding your question about why the back panels of Billy shelves often come loose, I would like to provide a structured answer:
1. Back panel material: The back panels are usually made from very thin particleboard or hardboard. These are significantly less sturdy than the carcass sides made of chipboard or MDF and are not designed to carry heavy loads.
2. Attachment method: As you correctly mentioned, the back panels are fixed with small nails or staples. These only withstand limited tensile and shear forces, especially when the shelf is moved or the wood adjusts over time.
3. Environmental factors: Fluctuations in humidity can cause the material to occasionally expand or contract. This effect is stronger with wood-based panels that are not sealed, which promotes the loosening of the back panel.
4. Assembly and use: Routed cables or tilting the shelf places additional stress on the back panel.
My tip: For long-lasting stability, consider securing the back panel afterward with additional screws or replacing it with a thicker, more robust panel material. Installing angle brackets also provides better stability than simple staples.
In summary, the problem usually lies in the combination of very thin material and mechanically inferior fastening, which is not designed for durable stability under load.
I hope this helps you!
Nabla64 schrieb:
Back panel material: Back panels are usually made from very thin particleboard or hardboard.I would like to add: The back panels are typically only about 3 mm (0.1 inches) thick, often low-density hardboard, which makes them brittle and prone to cracking. Attaching them with small nails or staples causes the panel to deform locally under stress. Over time, this leads to mechanical fatigue at the nail points.
Nabla64 schrieb:
Fluctuations in moisture can cause the material to expand or contract.This is a crucial factor! Especially in living spaces with high humidity (kitchen, bathroom), this causes swelling or shrinking, which can loosen the nail attachments.
I always recommend sealing the back panel with varnish or wood preservative before installation to reduce moisture absorption. Using screws instead of nails also significantly improves durability, as the back panel is then secured more firmly at multiple points.
I would be interested to know if farcanstan could describe the exact usage situation of the shelves? Are they placed directly against damp walls, or are they moved frequently, for example?
farcanstan24 Apr 2023 11:52Domau0 schrieb:
I would be interested to know if farcanstan could describe the exact usage situation of the shelves? Are they placed directly against damp walls or are they moved frequently, for example?Good question! The shelves are usually located in living rooms, quite far from sources of moisture, and are rarely moved. The humidity levels are generally normal to low, with no exposure to kitchens or bathrooms.
I have also noticed that the issue mainly occurs with the larger versions that are 80 cm (31.5 inches) or 90 cm (35.4 inches) wide – smaller shelves seem to be less affected. Maybe the length of the back panel plays a role in their vulnerability?
The back panels are originally fixed with small nails, as mentioned, but I haven’t altered the fastening method. Occasionally, the back panels make faint creaking sounds when moved, so there is some slight movement.
Are there typically any different construction features in the larger shelves that could affect the stability of the back panel?
farcanstan schrieb:
Are there usually different construction features in larger shelves that could affect the stability of the back panel?Yes, that does play a role: Wider shelves mean longer back panels, which are more prone to bending. Without enough cross-bracing, the back panel is more sensitive to pressure and tension forces.
Additionally, larger shelves often lack extra reinforcement for the back panel—especially in Billy-style shelves, which typically do not have diagonal bracing. This means that overall stability relies heavily on the back panel alongside the shelf frame.
For a long-lasting secure attachment, I would recommend fixing the back panel before any load is applied, for example by adding extra fasteners along the back of the shelf. Another option could be retrofitting a thin plywood sheet (e.g., multiplex 4 mm (0.16 inches)) to increase stability.
In general, the back panels supplied by the manufacturer are sufficient for light loads up to a certain extent, but with larger dimensions, their inherent weakness becomes more apparent.
