ᐅ Why do some Ikea Brimnes drawers stick or become difficult to open after assembly?
Created on: 21 Nov 2023 10:37
Dikerstin
Dikerstin
21 Nov 2023 10:37
I recently assembled a Brimnes dresser set from Ikea and noticed that some of the drawers are quite stiff after assembly. My question is: why do some Ikea Brimnes drawers stick or bind after putting them together? Specifically, I’m interested in whether this is due to incorrect assembly, material tolerances, wood swelling, or possibly a design issue. Are the drawer slides misaligned, or is it more likely that the drawers change due to the material or construction method? How can these problems be avoided, and what concrete steps can I take if the drawers don’t slide smoothly? I followed the instructions carefully, but the sticking persists. I look forward to your experiences and advice!
Wesley
21 Nov 2023 13:52
Hey Dikerstin, I know the problem – my inner perfectionist always gets tested by this! 😅 With Brimnes and similar Ikea models, jamming often comes down to a few common issues:
- The drawer slides are not mounted perfectly parallel or have slight alignment errors
- The drawers sometimes fit a bit too tightly in their tracks
- Wood expands, especially in high humidity, causing swelling
A little trick: treat the runners with some silicone spray or furniture wax, and the drawers will glide much more smoothly.
Don’t worry, this is pretty common with Ikea furniture – they’re designed for a good balance of price and performance, not for high-end custom cabinetry. 😉 So don’t get discouraged, we’ll get this sorted!
fredle
22 Nov 2023 08:23
Hello Dikerstin,
Your concern is very understandable, and the causes are usually due to some common reasons. Here is a detailed overview of the most likely causes when Ikea Brimnes drawers stick after assembly:
- Installation deviations: If the drawer slides are not mounted exactly parallel and at the correct height, the drawer can get stuck. The most common issue is that the screws are not inserted or tightened precisely, causing the guide to shift slightly.
- Material tolerances & wood swelling: Brimnes is made from coated wood-based panels (particleboard or similar). Even though IKEA prepares the panels, their moisture content can change, causing swelling and therefore tight spots.
- Missing adjustment: Unlike higher-end drawers, Brimnes dressers do not have sophisticated adjustment options on the slides. It helps to remove the drawers and possibly swap or carefully realign the slide rails.
- Manufacturing tolerances of fittings: Sometimes the drawer slides or rollers are slightly oversized or uneven, affecting smooth movement.
Recommendations to fix this:
- Completely remove the drawers and check all guides for a secure fit.
- Loosen the screws, realign the drawer slides, and tighten them.
- Then insert the drawers for a test run without fully closing them and check the sliding movement.
- If necessary, treat the drawer slides lightly with furniture wax.
I hope this helps! These issues are often a matter of fine-tuning and not necessarily a serious design flaw.
Paxton38
23 Nov 2023 17:09
I fully agree with this. Additionally, it should be noted that for the Brimnes series, the alignment of the metal rails in the side panel of our test unit clearly determines the smoothness of the drawer movement. Small deviations of just a few millimeters can be enough to prevent the drawer from sliding in or out properly.
Furthermore, it helps to check with a spirit level before final assembly to ensure the side panels are perfectly vertical to each other. Some users underestimate how significantly even slight angular deviations can affect the sliding direction.
Changes in wood moisture content are also relevant, although usually temporary and rarely the main cause since the surfaces are laminated. However, in damp rooms, slight swelling can occur, which rarely leads to severe sticking but can occasionally be noticeable.
Therefore, my practical recommendations are:
- Precise alignment of the drawer slides with additional measurements.
- Consideration of moisture exposure in the installation environment.
- If necessary, slight adjustment of the guide surfaces.
So, the drawer sticking is less a design issue and more related to installation and environmental factors.
