I recently assembled a Brimnes chest of drawers from Ikea, but the drawers immediately got stuck after being inserted. I’m curious about the common causes of this issue since I followed the instructions exactly.
My guess is that it might be related to the precise alignment of the drawer slides or the screw connections, but I would like to hear your experiences and advice.
Are there any known weak points or peculiarities with the BRIMNES that cause the drawers to stick? If so, how can this be reliably prevented or fixed?
I look forward to your feedback and thank you in advance!
RAMEO schrieb:
I recently assembled a BRIMNES dresser from Ikea, but the drawers immediately got stuck after being inserted.That really sounds frustrating, especially when you have followed the instructions carefully. I’ve experienced the same problem myself and know how annoying it can be. Sometimes with Ikea furniture, even very small deviations are enough – slight warping of the drawers or minimal inaccuracies in the slides can cause them to jam.
What helped me was double-checking the slides carefully and tightening all the screws again, but gently so nothing gets warped. If the drawer still sticks, it can help to use fine-grit sandpaper on the contact points as a preventative measure.
Often it’s a combination of small details. Are you sure all parts are properly seated and not pressing too tightly?
RAMEO schrieb:
Are there any known weaknesses or specific issues with BRIMNES that cause the drawers to stick?The BRIMNES system uses rails with built-in rollers that need to be precisely aligned. Common causes for drawers sticking include:
- Inaccurate installation of the drawer slides (they must be parallel and flush)
- Slight warping of the cabinet due to improper assembly
- Screws on the slides being over-tightened
- Drawer fronts being slightly warped, which can obstruct smooth movement
To resolve drawer sticking, I recommend:
- Checking all screws and ensuring they are correctly positioned
- Verifying that the drawer slides are parallel
- Adjusting the drawer by gently lifting or realigning it
These steps are generally important for furniture with roller-type drawer slides and usually solve the problem immediately.
elgla schrieb:
Sometimes with IKEA furniture, even very small deviations can cause issues – slight warping of the drawers or minimal inaccuracies in the tracks can already cause a blockage.Exactly, I can only confirm that. Especially with BRIMNES, it’s important that the carcass is assembled perfectly square. Even a minimal misalignment can cause the drawers to not slide smoothly or to stick.
When checking the rails with a ruler or a spirit level, you can often spot these small deviations.
Additionally, it is advisable to ensure that all screws are tightened with the correct torque. Both too loose or too tight screws can cause problems.
lideo schrieb:
I once had that issue; the track wasn’t properly locked into place.This is an important point. Assembly systems like those from Ikea are usually designed so that the sliding tracks must snap into a small groove or bracket. If this does not happen completely, it can cause scraping or jamming. It helps to briefly remove the drawer, carefully inspect the runners, and then reinstall them.
Additionally, for precision with BRIMNES, it should be noted that even a millimeter (0.04 inch) misalignment of the tracks can affect smooth operation. Therefore, always work with great care.
