ᐅ Why do some drawers in the Ikea BRIMNES series start squeaking after a while?
Created on: 14 Jul 2020 08:04
Elmedin10
Elmedin10
14 Jul 2020 08:04
Hello everyone, I’ve noticed that some drawers of my Ikea Brimnes wardrobe start to squeak noticeably after some time, even though I haven’t changed anything unusual. I’m particularly interested in why this squeaking seems to happen quite often with the BRIMNES drawers, even though the fittings and slides are basically functional and simply designed. Are there common causes like material fatigue, lack of lubrication, or friction due to the design? And maybe someone already has durable solutions or tips to prevent or permanently eliminate this squeaking? I would really appreciate expert opinions so I can address the problem effectively.
BARSAN
14 Jul 2020 08:29
The squeaking usually occurs due to dry metal sliders or plastic guides. Simply apply some silicone spray or a specialized lubricant to the tracks, and this will quickly eliminate the noise.
Kyler10
14 Jul 2020 09:47
Squeaking in Ikea BRIMNES drawers is often caused by the materials and design, especially the use of metal telescopic runners combined with particleboard. Friction between the metal and plastic rollers can increase over time if lubrication or maintenance is neglected. Stress points may also develop due to slight warping or settling in the wood load, which affects the alignment of the runners and leads to noise. A lasting solution is to regularly clean the runners and apply appropriate lubricants, such as silicone spray. Alternatively, replacing the runners with higher-quality models can sometimes help.
fepau
14 Jul 2020 11:03
Elmedin10 schrieb:
I am especially interested in why this squeaking seems to occur quite often with the BRIMNES drawers
Finding the cause is really important! I had the same problem, and what worked great for me was using a little effort and the right product (silicone spray!). The drawer slides became almost silent again! It’s not as bad as I initially feared. Give it a try, it usually helps! Unfortunately, it’s no surprise since it’s caused by friction and material wear – but we can handle that =)!
theota
14 Jul 2020 15:12
Kyler10 schrieb:
The friction between metal and plastic rollers can increase over time
It’s not quite that simple. The squeaking is often also a result of Ikea’s standardized solution: cheap, easy to produce, but problematic in the long run. Without regular maintenance, these are disposable products. Since Ikea tends to focus on quick sales, the “squeaking” almost encourages repurchasing or replacement. That’s obviously cynical, but it’s something to keep in mind. If you want a durable solution, it’s better to completely replace or modify the tracks.
barle
15 Jul 2020 07:18
Usually, it is enough to clean the rails with a dry cloth and then treat them with some graphite powder or silicone spray. This usually eliminates the squeaking noises. If this does not help, the rollers are often damaged.
