ᐅ Why do some BILLY shelves warp after several years?
Created on: 24 Nov 2024 08:37
Tawulfila
Tawulfila
24 Nov 2024 08:37
I have been wondering why some BILLY shelves show visible warping after years of use. Specifically, I mean that even well-maintained shelves sometimes sag or bulge in certain areas.
I am particularly interested in whether these issues are solely due to the material quality, or if factors such as humidity, load, or perhaps even installation errors play a greater role.
Are such deformations a known issue with BILLY shelves that can be prevented with specific measures, or are they rather isolated cases?
I would appreciate it if you could share your experiences or informed opinions on this topic.
neoren
24 Nov 2024 09:12
Deformations often occur due to excessive or uneven loading. The load limits specified by the manufacturer are frequently exceeded, causing the wood to warp. Moisture can make the problem worse.
Filippo
24 Nov 2024 11:43
neoren schrieb:
Deformations often occur due to excessively heavy or uneven loading.
This is definitely a key point.
To truly understand the causes of deformations in BILLY shelves, one should first know that they are mainly made of particleboard, which behaves differently under load and moisture than solid wood. The panels are relatively thin and often use a thickness of about 1.5 cm (0.6 inches), which allows for some flexibility in larger shelves.
When heavy loads are placed on a single shelf level without proper intermediate supports or braces, the weight is not distributed evenly. Particularly problematic are single heavy items placed in the middle or in positions without lateral support.
Tawulfila schrieb:
…whether factors like humidity, loading, or possibly assembly errors play a greater role.
Regarding humidity: particleboard swells when exposed to high moisture, which can be noticed as edge swelling or slight warping. This effect increases in poorly ventilated rooms or with strong fluctuations in indoor climate (e.g., humidity spikes or heated air during winter months).
Assembly errors are also relevant – if the shelf is not perfectly level or the joints are not correctly installed, tensile and compressive stresses on certain parts increase, which can negatively affect durability.
I would like to know: How long have you been using your shelf, and how is it normally loaded?
koduga
25 Nov 2024 07:29
I can relate to this problem well because I have a shelf myself that sags after a few years – honestly, I was quite disappointed by that at the time.
Filippo schrieb:
Wood particle boards swell with high humidity, which you can notice as edge swelling or slight warping.
I can confirm that. In my case, the indoor air quality was not always optimal, especially during winter with dry heating air and then again in the humid summer months.
I believe that storage conditions play a bigger role than I initially thought. Also, paying attention to load limits and regularly checking the shelves helps to avoid serious damage.
I would be interested to know if there are affordable tips to extend the lifespan of shelves – maybe special dehumidifiers or additional reinforcements?
Kinbu
26 Nov 2024 18:54
Hello, I would like to add a few points since I have dealt with this topic several times before.
First of all: BILLY shelves are popular for their price-performance ratio, which means accepting compromises in material thickness and stability. Their design offers flexibility but not the sturdiness of solid wood furniture.
Regarding deformation:
1. For heavy shelf loads, it is advisable to support drawers or shelves with additional braces.
2. Horizontal reinforcements or cross braces at the back can help keep the shelf stable.
3. Installation is crucial: If the shelf is not firmly secured to the wall but only stands freely, it can more easily shift and warp.
Exactly, dehumidifiers or maintaining a consistent room temperature with controlled humidity can protect the material. It is also recommended to arrange the shelves so that heavier items are placed lower and lighter ones higher—this avoids unnecessary pressure on the shelves.
If you want, I can also provide detailed information on reinforcements and installation options.
