ᐅ Why do some BILLY shelves warp after installation?
Created on: 28 Feb 2023 18:07
Helgebar
I am currently looking into the issue of why some shelves of the IKEA Billy bookcase visibly warp after installation. I am particularly referring to distortions that appear as bowing or sagging of the shelves, even though they should be straight and stable. My suspicion is that this may be related to material properties, storage conditions, or moisture.
I would like to better understand why particleboard shelves in the Billy bookcase are so prone to warping in practice. What causes are relevant here? Are there known technical or manufacturing reasons? And are there any tips on how to prevent or at least minimize this warping?
Thanks for your input!
Z
zarHenning
1 Mar 2023 09:12
I had the same problem once. For me, it helped to store the shelves flat and dry for at least 48 hours before installation – that never hurts.
If the shelves are already warped, there are few tricks. Sometimes you can flip them over and weigh them down heavily, but this rarely works long-term.
Helgebar
2 Mar 2023 11:05
BAUEVA schrieb:
Gluing and surface coating play an important role
I’ve noticed that especially with low-cost furniture, the back side of the shelves is often barely coated, which causes them to absorb more moisture.
Dilen schrieb:
A central load without cross supports worsens the problem of deformation
That sounds plausible, especially since I’ve observed that the middle section sags even more under heavier loads.
Can we say that the problem is often a combination of moisture, insufficient coating on the back side, and excessive point loads? Are there any suggestions on how to improve the coating on the back side? Thanks for the insights so far!
Dilen
2 Mar 2023 12:29
Helgebar schrieb:
So, can it be said that the problem often results from a combination of moisture, lack of coating on the back side, and excessive point load?
Exactly, Helgebar.
A few details:
- Backside melamine coatings are often omitted to save costs or are very thin. This makes the underside more vulnerable.
- Applying an additional protective layer (e.g., paint, clear coat, or special sealant) can help reduce moisture transfer.
- Load: Shelf boards are often 56 cm (22 inches) deep, which is quite substantial. Cross supports or additional braces effectively relieve the middle area.
One recommendation: Pre-treating with an appropriate wood preservative is possible if you want to do it yourself, but usually at your own risk.
Have you already noticed in which room and under what conditions the shelf boards are warping for you?
