ᐅ Why do some BILLY doors warp after a certain period of time?
Created on: 21 Feb 2023 14:07
Annikaix
Annikaix
21 Feb 2023 14:07
I have been experiencing an issue for some time now where the doors of my Billy bookshelf have warped after a certain period of use. I wonder why this happens. Could it be due to material defects, installation errors, or possibly external factors like humidity?
My BILLY doors are from the standard range, and I installed them about a year ago. At first, they fit perfectly, but after a while, it became clear that the doors no longer close flush and the edges are bending. I would like to understand the exact causes of this deformation—after all, these are quite simple wood-based materials.
Are there any technical insights or experiences you could share?
Thanks in advance!
Cecilera66
21 Feb 2023 14:22
This is usually due to moisture. BILLY doors are made of particleboard with a veneer. When the wood swells, the doors warp. It is important to keep the humidity levels fairly consistent.
Tevin
21 Feb 2023 15:10
Hello Annikaix,
I agree with @Cecilera66 and would like to add that warping can also be caused by temperature fluctuations and uneven loading. The doors are not solid wood but made from particleboard with a decorative surface, which makes them more susceptible than real solid wood.
Cecilera66 schrieb:
Usually, it is due to moisture.
Very high or strongly varying indoor humidity significantly increases the risk of warping.
If the doors are frequently used or heavily loaded, this can also affect the hinges and the shape of the door.
V
vin_leo
21 Feb 2023 16:52
The BILLY doors are really practical, but it’s important to remember that the material is just lightweight construction.
Annikaix schrieb:
After a while, you can clearly see that the doors no longer close flush and are bending at the edges.
That sounds like they’ve become a bit warped due to stress or moisture. This often happens if BILLY is placed in damp basements or near a heater. Try adjusting the doors slightly or improving the room’s humidity.
Small tricks like loosening or readjusting the hinges often help as well 🙂
JEREMIAH38
22 Feb 2023 09:18
I understand the problem very well and have experienced a similar situation myself. It is frustrating when you have nice furniture and then notice such deformation.
Tevin schrieb:
It can be caused by temperature fluctuations and uneven stress.
That’s exactly what makes it difficult – people often don’t realize that BILLY doors are not designed to handle excessive moisture or heavy loads. Additionally, the installation can play a role: if the hinges are not aligned properly, warping can be worsened.
It really helps to patiently make adjustments and keep an eye on the indoor climate data.
In my opinion, you shouldn’t give up on the furniture too quickly but rather keep working on it!
todunar
22 Feb 2023 10:44
It’s great to see so many practical tips coming together here!
I also have BILLY doors that warped slightly after a few months – but a bit of adjustment on the hinges and avoiding excessive moisture worked wonders!
JEREMIAH38 schrieb:
you shouldn’t give up on the furniture too quickly, but rather stick with it!
Exactly, it’s worth it! And: you really feel clever when you solve the problem yourself :-)
Keep at it, everyone, and don’t get discouraged! 🙂
