ᐅ Why do some BILLY doors stick slightly?
Created on: 10 Sep 2023 08:43
arefneo
I have noticed for some time that the doors on my IKEA Billy bookcase sometimes stick slightly when I open or close them. The question I have is: why do some BILLY doors stick a little? At first glance, all the doors seem to be installed and adjusted the same way, yet there are differences in how smoothly they move. Could it be due to the installation, or is it more likely related to material variations or changes caused by environmental factors? If anyone has experienced this or knows the cause, I would like to learn more to find a suitable solution.
pikin
11 Sep 2023 13:04
LOGEMIN schrieb:
1. Check the hinges: Are they correctly installed and firmly screwed in?
I agree. The precision required for hinge adjustment is often underestimated. Even a slight misalignment can prevent doors from moving properly.
noge58 schrieb:
It also helps not to tighten the screws too much, so there is some play.
That can be helpful, but they shouldn't be too loose either, or the door will hang crooked. So always adjust with care.
tra_nina
11 Sep 2023 16:22
arefneo schrieb:
Could it be due to the installation or rather material differences or changes caused by environmental factors?
You have already narrowed down the question well. In fact, the installation plays the biggest role. For workpieces in this price range, the material is standardized and consistent, but engineered wood reacts sensitively to moisture.
Anyone who wants to lightly sand and properly adjust the doors should carefully work with the screw adjustment of the hinges and possibly use a special hinge adjustment tool.
gesar32
12 Sep 2023 08:33
Additionally, I would like to mention that in rare cases, manufacturing tolerances at IKEA can also play a role. While BILLY is generally produced with high precision, slight variations in the cutting of the doors can occur, which may result in them sticking. It is worth checking the individual components before starting assembly. If a door is indeed warped, IKEA often replaces it as a goodwill gesture.
arefneo
13 Sep 2023 10:19
Thank you for the summary. It confirms that I need to keep working on adjusting the hinges.
gesar32 schrieb:
It’s worth checking the individual components before starting assembly.
I will definitely do that with my next furniture purchase.
Do you have any tips on how to best adjust the hinges without applying too much force?
