I have been using IKEA Billy bookcases for a while now, and I have noticed that some of the doors start squeaking after some time when opened or closed. I’m curious why only certain doors squeak, while others remain completely silent.
Are there specific mechanical reasons? Could it be related to the type of hinges, the material, or perhaps how the doors are adjusted? Maybe environmental factors like humidity or temperature also play a role?
I would like to better understand why this squeaking occurs in order to hopefully prevent or fix it. If anyone has experience with this or can provide a technical explanation, I would appreciate it. Thanks in advance!
Parlis schrieb:
I’m still wondering if you have any experience with how long hinge maintenance on Billy doors typically lasts? To be considerate of the customer, you should perform maintenance at least once a year, especially if the furniture is used frequently. Generally, the hinges are durable enough to last for many years with regular care. However, if the door starts to become difficult to move, creaks, or squeaks repeatedly, this can also be a sign of material fatigue or early damage to the hinge.
If this happens, it’s better to replace it early – hinge sets are affordable at IKEA.
Important: Also make sure the door is properly aligned. A misaligned door increases stress on the hinges and speeds up wear.
Just as an addition: If you don’t want to apply lubricant every year, you can try to relieve the Billy doors by adding rubber buffers or felt pads at the contact points. This reduces friction and can lower the overall squeaking.
Of course, it’s not 100% protection, but a nice little trick to make your home a bit quieter 🙂
Parlis schrieb:
I was also wondering if the squeaking could be an indicator of early damage or material fatigue? Very good question. In fact, squeaking can indeed be an early warning sign. Changes in friction noises often indicate whether the hinges are still operating smoothly and flexibly or if they are already being overstressed.
I recommend performing a targeted visual inspection when new squeaking noises occur: Are there any cracks visible on the plastic bushing? Are the screws still tight? Has the metal possibly become worn out or stretched? If so, it’s better to replace the parts early to avoid bigger damage.
In summary: The squeaking itself is not necessarily a sign of an imminent break, but it is a clear warning that should not be ignored.
