ᐅ Why do some BILLY doors squeak on a daily basis?
Created on: 17 Jan 2023 08:43
chenpi
chenpi
17 Jan 2023 08:43
I have a question that has been on my mind for some time: Why do some Billy doors squeak almost daily, even though the furniture piece is otherwise in perfect condition? I’ve noticed that the noise mostly happens when opening and closing, and unfortunately does not go away over time. My guess is that it has to do with the hinges, possibly material friction or some wear and tear. However, I clearly lack the technical understanding to identify the exact cause. Perhaps there is a general design weakness behind the problem. Has anyone experienced this or can explain which mechanisms in BILLY furniture cause the squeaking and, most importantly, how to permanently eliminate it?
Jeanbar
17 Jan 2023 09:12
Hello chenpi, your question about the frequent squeaking of the BILLY doors is very understandable, as this noise is often annoying and can unsettle users. In most cases, the squeaking is caused by metal-on-metal friction in the door hinges. These hinges in IKEA BILLY shelves are quite simple in design and operate without dampers or special bearings, which means that over time dirt, dust, or even dryness leads to increased friction.
Many people solve the problem by spraying the hinges with silicone spray or special lubricating oil. Caution: greasing with regular oil can attract dust and make the problem worse. Occasional cleaning of the hinges also helps prevent squeaking.
Sometimes, however, a slight misalignment of the door can also amplify the noise. So check if the door fits tightly or if it is sticking somewhere.
chenpi schrieb:
I have noticed that the noise mostly occurs when opening and closing and unfortunately does not go away over time.
This actually confirms the typical wear caused by friction. In summary: clean, lubricate properly, and adjust if necessary—this usually helps.
Gofoman
17 Jan 2023 09:57
I believe you shouldn’t focus too much on using lubricants. Maybe the squeaking on BILLY doors is simply typical for this price range and construction. IKEA is optimized for affordable mass production – not every component is designed for longevity with expensive materials and complex mechanics.
Jeanbar schrieb:
these are quite simply designed on IKEA BILLY shelves and run without dampers or special bearings
Exactly. A simple, cost-effective solution. I even bet that some customers hardly notice the squeaking at first until the community highlights the issue and everyone suddenly becomes very sensitive to it. The cause lies in the design. If you don’t like it, you probably have to buy more expensive shelves. Everything else is at best just a fig leaf.
I’m doubtful that the squeaking can really be avoided.
bupar
17 Jan 2023 11:34
The squeaking of BILLY doors is primarily caused by friction on the metal hinges. These hinges come unlubricated from the factory. Moisture, dust, and temperature fluctuations further affect the material, which increases the noise.
It is recommended to clean the hinges with a dry cloth, followed by treatment with silicone spray. Regular oil or grease is not suitable, as it attracts dirt and can cause the mechanism to jam.
Adjusting the door may also help if it does not fit precisely within the frame. Frequent daily use can contribute to noise development, but with proper care, it is usually not a persistent problem.
Nofege
18 Jan 2023 14:26
Here is a brief guide on how to permanently reduce squeaking in BILLY doors:
1. Preparation: Carefully open the door and expose the hinges.
2. Cleaning: Use a lint-free cloth to remove dust and dirt from the hinges. For heavy buildup, an isopropanol swab can help.
3. Lubrication: Then apply a suitable silicone-based lubricant to the hinge bearings – this reduces friction without attracting dust.
4. Adjustment: Check if the door hangs straight. Use a screwdriver to slightly adjust the hinges to prevent misalignment.
5. Repeat: For doors that are used regularly, repeat this process every few months.
A common mistake is using oil or grease – these attract dust and cause increased squeaking over time.
This method has proven to be very reliable in practice.
chenpi schrieb:
vor allem, wie man dieses dauerhaft entfernen kann?
Therefore, the recommendation is: don’t just lubricate once, maintain regularly.
elgla
19 Jan 2023 07:59
I understand that the squeaking can be really annoying, especially when the piece of furniture is otherwise in great condition. But it also shows that you care about having a functional, durable interior—which I think is important and commendable.
From my own experience with our BILLY shelves, I can say that I also found the squeaking really frustrating at first. It can help to move the doors gently, rather than roughly. This prevents the friction from increasing.
I think it’s good that there are tips on maintenance here, as it makes you feel less helpless. If it doesn’t improve, you can also consider whether hinge repair kits are an option, or if replacement is necessary. I’m keeping my fingers crossed that you’ll get the problem under control! 🙂
