ᐅ Why do some BILLY doors no longer fit properly after being moved?
Created on: 8 Oct 2018 14:23
Giluku
Giluku
8 Oct 2018 14:23
Hello everyone, I recently moved to a new apartment and took my IKEA BILLY bookcases with doors along. After the move, I noticed that some of the doors no longer fit properly—they don’t close flush or are either too tight or too loose in certain spots. My question is: why do some BILLY doors not fit correctly after moving, even though everything was assembled exactly the same way? Could this be due to the installation, changes to the furniture itself, or external factors like temperature and humidity? I would appreciate a well-informed explanation so I can better understand the issue and fix it myself.
kegibu
8 Oct 2018 16:51
Hello Giluku, you’ve raised an interesting topic. The fitting of BILLY doors can be affected by several factors – here is a structured explanation:
1. Wood swelling and relocation: Changes in moisture, caused for example by different humidity levels at the new location, can cause wood components or the particleboard material to swell or shrink slightly. This results in minimal changes in dimensions, which can quickly become noticeable in the doors.
2. Assembly accuracy: Even small deviations during assembly, such as a hinge being screwed in slightly crooked, can affect how well the doors fit the cabinet frame. After moving, there is sometimes a rush and measurements are not always as precise as during the initial assembly.
3. Wall and floor unevenness: The new location is not always perfectly level to the millimeter. Cabinets may be slightly tilted or the floor may not be completely even. This can also cause the doors not to close perfectly.
4. Wear and stress: If the furniture was carried or moved at an angle during the move, small deformations in the material can occur, affecting the fit.
My tip: First, check the hinges and adjust them if necessary. Then use a spirit level to check the cabinet frame and, if needed, level it. If the material is swelling, you should wait a few days for the wood to acclimate to the new environment. This should help restore the proper fit of the doors.
Layla
9 Oct 2018 09:37
You summarized that very well, kegibu. From my own experience, I can add that during my move I also noticed how sensitive these furniture parts are to even the smallest changes. It almost seems like the doors “go along” with the move but don’t really return exactly to their original position.
At first, it was quite frustrating because you expect to rebuild everything exactly the same. But then I realized that even the tiniest variation in the wall or floor can change the whole situation.
So, it’s important not to get too stressed if the doors stick or don’t close perfectly at first. Usually, this can be fixed with some patience, adjustments, and fine-tuning. 🙂 Still, I find it very helpful to keep in mind the issues of wood swelling and expansion due to humidity – this is often underestimated.
INGRID34
9 Oct 2018 22:46
Simple solution: Check and adjust the hinges, inspect the floor for levelness, and align the furniture precisely. Issues caused by material deformation are usually temporary, as wood adapts over time. If the problem is severe, door stops can be easily adjusted.
kegibu
11 Oct 2018 11:12
INGRID34 schrieb:
Check and adjust hinges, verify floor levelness, align furniture precisely.
Exactly – additionally, I would like to mention that IKEA’s BILLY series also includes small adjustment options on the hinges. These allow you to fine-tune the doors in three dimensions (up/down, sideways, depth).
So if the doors don’t fit properly after the move, it’s worth systematically checking these adjustment screws. Also, a hinge may become slightly loose during transport, which isn’t always immediately noticeable.
One last tip: if the doors still don’t close properly after adjustment, it can help to check the seals or inserts on the door frames to make sure they are still in the correct position or haven’t shifted. This can quickly compensate for small annoying gaps. By the way, it’s recommended to transport furniture upright and carefully during a move to avoid deformation 🙂
